Need trailing arms
Old Jun 8, 2009 | 11:57 AM
heterodox1's Avatar
heterodox1
Need trailing arms
Hi all,
I was under my 2000 Exp. yesterday and realized my trailing arms are in terrible shape. Questions:
What happens if a lower trailing arm breaks when I'm on the highway?
Is this strictly a dealer part?
Any aftermarket sources?
Do the bushings come with it or do I buy these separately?
Thanks for any input you have!
Old Jun 8, 2009 | 07:33 PM
MisterCMK's Avatar
MisterCMK
I sourced mine from the dealership. I think they were only $60 or so and that included the bushings. Install couldn't be easier either.
Old Jun 18, 2009 | 11:51 AM
heterodox1's Avatar
heterodox1
Where did you get these for $60? This is a great deal. The best deal I found was $510 for the set of all four. Oh well, I've got a bunch of long trips planned with the family this month and I don't want to mess around, so I got them...
Old Jun 18, 2009 | 08:23 PM
fred_79f250's Avatar
fred_79f250
Changed em on my 2000 Expy too - strictly a dealer part - dealer's computer had a note - new lower trailing arms are 1/4" SHORTER than the original. Normally you'd change one at a time so that the other holds the axle in place, but because the new ones are shorter you can't do that - you gotta remove em both, but the shocks and springs will want to rotate the axle, so you gotta hitch it up to something by the shock mounts to rotate it slightly so the new ones will fit.
Also, if you jack it up by the frame, the arms get at radical angles that make changing them difficult.
Old Jun 18, 2009 | 08:41 PM
heterodox1's Avatar
heterodox1
Thanks for the advice. Seems like there are a bunch of us having this trouble all at the same time. I'll try it this weekend...
Old Jun 19, 2009 | 12:14 PM
MisterCMK's Avatar
MisterCMK
I bought them from Tousley Ford in the Twin Cities. They have a deal for Mustang and SVT club members.
Old Jun 19, 2009 | 12:15 PM
MisterCMK's Avatar
MisterCMK
BTW, here is what mine looked like before I replaced them.
Old Jun 22, 2009 | 11:53 AM
heterodox1's Avatar
heterodox1
Well the lower ones are replaced. Thank goodness because I had 2 or 3 holes in each one. They were even worse than I thought... The only problem I had was getting the left-front bolt out. It pushes right against the gas tank and won't come out far enough to remove the arm easily - what a pain. I'll wait on the uppers because they don't seem as bad.
...and the new ones are actually slightly LONGER than the old.
Old Jun 23, 2009 | 09:14 AM
98expeditionXLT's Avatar
98expeditionXLT
How did you take care of getting the left front bolt out?
Old Jun 23, 2009 | 11:56 AM
heterodox1's Avatar
heterodox1
Here is what I did...
I thought about cutting the bolt off but I'm glad I didn't.
After taking the rear of the arm off, I twisted it to the side a little bit - this caused the bolt to angle slightly toward the front of the gas tank. With the bolt squeezed against the gas tank and over the skid plate, there is no way to get a socket or wrench in there so I started to work it out with pliers (by turning the shaft). Once I realized I was starting to press into the plastic gas tank pretty bad, I put a heavy jar lid (piece of metal) between the bolt and the tank. It still put a lot of pressure on the tank but at least it was not gauging it anymore. With the arm angled to the side, the threads of the bolt will grip and come out most of the way - enough to squeeze the arm out. Hope that make sense?
