62 to 66 Cab questions
I had a bad winter here in CT, a noce ole Icestorm came thru and a tree fell on my barn where i was storing my 66. it pretty much destroyed my cab and front clip, cracked the bellhousing from a branch piercing thru the cab. My old highschool buddy has a parts truck a 62, and doesnt need the cab? what are the differences between the two, will the 62 fit on my 66 or am i just limited to 65 and 66 cabs only?
sorry to hear the bad news.... the 61 to 64 cabs are not the same as the 65-66 the floor is different, the roof line is different, the frame to cab mounts are different, (on the front of the cab) probly more stuff as well. you may want a 65 to 66 cab so everything will bolt right up without any problems.
good luck with it.
good luck with it.
good luck with it.
good luck with it.
The roof panel is the same 1961/66, only the drip rails are slightly different on 1965/66's, using different joint clips.
The back of cab sheet metal is the same 1961/66 except for Uni's. The doors are the same 1961/66 except for Uni's. All the glass is the same 1961/66.
The rubber cab mount insulators are the same: 1964/66 F100/250, 1967/72 F100/350.
The only real difference between the cabs is the firewall and the floor pan.
