fuel tank interchange
Old Jun 7, 2009 | 07:00 PM
82ford302's Avatar
82ford302
ok i have an 86 ext cab shortbed 2wd truck, and i have a parts 91 ext. cab truck. will the tanks from the 91 physically fit under my 86?
Old Jun 7, 2009 | 07:05 PM
dustybumpers's Avatar
dustybumpers
they should, you have to measure them, you didd'nt say if the 91 is a short bed or not
Old Jun 7, 2009 | 07:08 PM
82ford302's Avatar
82ford302
the 91 is a longbed. im also using the lines from the longbed and try to make it work with my 86.
Old Jun 7, 2009 | 08:14 PM
dustybumpers
I'm not sure when ford changed it, mabe 84? but the sending unit/pump hole went from small to large hole. 91 is efi with 1 pump, not sure what engine your 86 has, I6 has mechanical fuel pump on engine all others have electric fuel pump. the fuel pump system changed in 90,old system had lift pump in tank, high pressure pump on frame. 90 and newer had pump in tank only. back tank will physically fit for sure, front tank may be too long.
Old Jun 7, 2009 | 11:18 PM
82ford302's Avatar
82ford302
yea my 86 is fuel injected. it has the pump in tanks and on the frame rail. if i could just get the back tank to work that will be great.
Old Jun 8, 2009 | 12:34 AM
Dean88's Avatar
Dean88
Yes it will fit, I've heard of several people putting the 32 gal bronco tank in these trucks
Old Jun 8, 2009 | 04:43 AM
dustybumpers
change the pump in the tank, and your good to go
trollin91x250
Feb 11, 2013 09:06 PM
dragonmaster093
Jan 20, 2010 09:56 PM
Redneck86ford
Jul 22, 2007 03:57 PM
Dustin_86
Dec 21, 2003 03:26 PM
