Lawn mower engine.
Old Jun 6, 2009 | 08:49 PM
tcbofade's Avatar
tcbofade
Lawn mower engine.
Dumb question...where does one find a used lawn mower engine?
New ones cost more then the flippin' mower did.
Old Jun 6, 2009 | 08:53 PM
Bdox's Avatar
Bdox
Mostly on used lawn mowers............ What the hcll, just buy a used mower!!!
Old Jun 6, 2009 | 09:07 PM
tcbofade's Avatar
tcbofade
I'm quickly discovering that...sheesh.
Old Jun 6, 2009 | 09:09 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Dang it, you beat me to it. First thought when I read this.....
The beauty of the second amendment is that it will not be needed until they try to take it. - Thomas Jefferson
Old Jun 6, 2009 | 09:16 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Try to get that kind of info anywhere else...
Old Jun 6, 2009 | 09:23 PM
Bdox's Avatar
Bdox
I'm tellin ya! A great deal of research and long experience leads up to this kind of conclusion.
Old Jun 6, 2009 | 09:56 PM
tcbofade's Avatar
tcbofade
Thanks heaps you weenies...I found a similiar engine on Craigslist for $100. I emailed the guy and will try to go pick it up sometime this week...
Old Jun 6, 2009 | 10:00 PM
Lead Head's Avatar
Lead Head
What brand is the engine? If it is a Tecumseh, you may want to stock up on parts while you still can. They discontinued production of all their engines, and parts to go along with them.
Old Jun 6, 2009 | 10:02 PM
tcbofade's Avatar
tcbofade
The engine I have a Briggs and Stratton...with a broken connecting rod.
Messed up the crank shaft.
I think I can just swap in another motor for less than the cost of fixing the one that I have.
Old Jun 6, 2009 | 10:07 PM
Bdox's Avatar
Bdox
A used mower should run about $50.
Old Jun 6, 2009 | 10:14 PM
tcbofade's Avatar
tcbofade
It's a 46 inch riding mower, Bruce.
It's $3,000 new and $1,200-$1,500 used.
I bought it for $50.
Old Jun 6, 2009 | 10:17 PM
SteveBricks
FTE Emeritus
The knowledge here is unsurpassed!!
Old Jun 6, 2009 | 10:34 PM
Bdox's Avatar
Bdox
Good work Terry!!! Do it again!
Old Jun 6, 2009 | 11:39 PM
jake00's Avatar
jake00
Originally Posted by Lead Head
They discontinued production of all their engines, .
I've never met anyone who said they built a quality motor
Old Jun 7, 2009 | 07:57 AM
ckal704's Avatar
ckal704
I never liked working on Tecumseh pushmower engines. It seems like every engine took a different gasket whereas the same sump gasket would fit 90% or more of Briggs engines. Their valve compartment was always too tight to conveniently use my favorite valve spring retainer tool, and those damn internal ignitions were a pain in the *** to service and adjust compared to Briggs.
I will give them credit for using pressurized lube on even their smallest engines, but since I have seen many splash lube briggs engines living far beyond engineered life-spans with good maintenance, I don't know that the extra cost was worth it.
Craigslist is a great place to find used engines (on used lawn mowers). Main thing you need to watch, after determining that the used engine is in good running condition, is that you get one with the same external crankshaft dimensions so that you pulleys fit and line up.
