NEED HELP!! 6.0 throttle quits
Old Jun 6, 2009 | 08:20 PM
78powerstroke's Avatar
78powerstroke
Hi people,I have a couple problems to talk about.First is I have some type of problem with my throttle pedal kicking out.At first I could shut the truck off and restart and go.Then it it got worse and would do it every time I would hit the brakes or turn the right signal on or the hazard lights.I have looked for shorts in the wiring and haven't found anything.All the lights work except my reverse lights, which haven't worked since I bought the truck in 05.That is problem #2.#3 is the fuel gauge has never worked either.But back to my original problem,I have tried 3 different pedals so I am pretty sure that is not it.It will throw codes-P2138,P2139,P2140.Which all come up to voltage correlation issues.Has anyone seen anything like this? Could it be in the PCM or FICM or something like that.The truck is an '04 with auto tranny F250 XL with 36,000 miles.Thanks,Steve.
