Balancer Self Destructed
Old Jun 5, 2009 | 04:06 PM
Automator's Avatar
Automator
While my engine was out about 7,000 miles ago (2 month) it was determined best to change the harmonic balancer. We replaced it with a new Ford unit and last week I changed the belt because the old one with over 120K miles on it broke. On Monday it started to make a racket about when I got to work. On further investigation we found the belt was no longer running on the pulley and then noticed the pulley was back toward the engine and not running. I saw the old pulley and balancer yesterday and you can just slide them through. Anyone experience anything like this before?
Old Jun 5, 2009 | 04:15 PM
Kwikkordead's Avatar
Kwikkordead
Are you saying that the old balancer just slides onto the end of the crankshaft?
Old Jun 5, 2009 | 04:33 PM
Automator's Avatar
Automator
The old pulley slides in and out over the old balancer. rubber still there but slides right over. I am not a mechanic, but the assembly seemed to be a round sheave then a layer of rubber and then the pulley. While there is still some rubber on the pulley, there is a layer of it missing that is enough for the pulley to be slid over the balancer sheave without and resistance.
Old Jun 5, 2009 | 04:55 PM
Kwikkordead
Your balancer came apart again, HMMMM.
Your mod list is nothing really high HP.
Can you get onto the end of the crankshaft with a 24mm 12 point socket and rock the engine back and forth?
Old Jun 5, 2009 | 05:29 PM
Automator's Avatar
Automator
I can give that a try tomorrow. Your right, the only "real" mod I have is the S&B Intake though it has just hit 308K miles but everything seems tight.
FSJ-EARL
Jul 18, 2013 07:25 AM
LTCPipkin
Apr 24, 2011 02:22 PM
spiderarana
Jul 3, 2010 07:55 PM
1pump
1978 - 1996 Big Bronco
Nov 11, 2004 11:56 PM
