Does Flex Fuel make a difference
Old Jun 5, 2009 | 01:02 PM
VoodooRacer's Avatar
VoodooRacer
I believe my 06 is the Flex Fuel model. Does this make a difference when you are ordering parts for the motor, tuners etc...
Old Jun 5, 2009 | 02:36 PM
sammer4u's Avatar
sammer4u
Not necessarily... I believe most parts are the same, but some of the fuel line parts may not be due to the Flex part... Plugs, and stuff like that are the same...
Old Jun 5, 2009 | 02:41 PM
VoodooRacer
ok just wanted to make sure
Old Jun 5, 2009 | 03:38 PM
Still Smoking's Avatar
Still Smoking
Im not sure if the tuners would be the same. I mean I might be wrong but I have heard that E85 robs you of gas mileage and hp so if you put a normal tuner in there its usually set for a certain temp and stuff right? I would think you would need a tuner made for E85 unless you run gas all the time. But Im probably wrong cause Im no mechanic by any means at all.
Old Jun 5, 2009 | 04:06 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
they are the same physically
The only real difference is the fuel filter...but all later 06-08 trucks have it also
Tuning wise, DO NOT RUN E-85 WITH AFTERMARKET TUNES. You'll be okay running tunes as long as you stick with 87/89/91/93 octanes...running E-85 will cause the PCM to shift feul maps and might blow the motor
But yeah, you can run everything on a FFV
Btw, look at you VIN. In the 5th position you'll see either a "5" or a "V".
5=regular 5.4
V=Flex Fuel
Old Jun 5, 2009 | 04:17 PM
Ryan50hrl's Avatar
Ryan50hrl
Hum....now since E85 is about 100-105 octane....why couldn't you run it on the premium tunes???
Old Jun 5, 2009 | 04:25 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
You probably could...but it's just one of those things IMO that it's better to not try
I've heard of guys running custom written E-85 tunes though. But I personally would be very leery of that
Give it a try and let us know...but don't be surprised if you get a burnt piston or 2
Old Jun 5, 2009 | 06:58 PM
Ryan50hrl's Avatar
Ryan50hrl
Nah...i'm quite happy with my stock 300 hp......it keeps my very very very pricey tires intact better......LOL
Old Jun 5, 2009 | 07:41 PM
bridge's Avatar
bridge
Sick 'n Tired
I've run E85 with my Edge. All the performance of level 3 at a fraction of the unleaded gas efficiency. Other than the crappy mileage I don't have any problems. Given that ETOH is an excellent solvent running a tank every now and then helps keep things clean.
Old Jun 5, 2009 | 10:26 PM
VoodooRacer
i wasnt planning on running any of the tunes with the flex.
I also read on Wiki that the 5.4 with flex actually had more torque and horse with the stock tunes. I know Wiki can be made up but i was just curious if anyone had the numbers of whether this was true or not. Seems like it makes sense if the computer componsates for the higher octane that Ethanol has.
Old Jun 5, 2009 | 10:49 PM
bridge's Avatar
bridge
Sick 'n Tired
I haven't noticed any increase in power/torque running E85, running a tune or not. If anything, the truck tends to run a little rougher...
Old Jun 6, 2009 | 12:05 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
The 2009 5.4 gets 10 more HP/TQ on ethanol
The 04-08's are 300/365 on both...the ECM isn't programmer to optimize the extra octane
Old Jun 6, 2009 | 08:42 AM
VoodooRacer
ok thats prob what i read
Nelson_2011
Modular V10 (6.8l)
33
Jun 8, 2016 02:32 PM
shift1313
33
Apr 23, 2009 10:24 PM
AZDesertRat
2004 - 2008 F150
23
Feb 2, 2006 08:42 AM
el conquistador
1983 - 2012 Ranger & B-Series
Sep 14, 2004 10:54 PM
shredmyhead
Apr 1, 2004 03:25 AM
