6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Engine oil dip stick readings
Old Jun 14, 2009 | 07:25 PM
madmax99's Avatar
madmax99
Originally Posted by ctfordguy
I think the dipstick is fine, it is the user that is having the problems, and that is the problem with the auto industry and the country as a whole,, people cant think for themselves. The dipstick is not designed for and will not tell you if there is exactly 15 quarts of oil Rather you need to use a little common sense here. As long as the oil is on the plastic piece you are fine.
Then what's the point of a min max line on the stick, a design flaw? does that common sense part apply to things like torque spec's and min and max temps or fluid specifications?
The fact is the dip stick design sux's period. Yea it will work as long as you don't over fill but for the money we spent for these trucks it should be some what accurate.
daveya48187
Escape & Escape Hybrid
Jul 7, 2017 01:42 AM
dkj313
Mar 17, 2017 05:29 PM
CapePowder
1997 - 2003 F150
Sep 8, 2016 09:13 PM
brian.b
Jan 11, 2016 02:54 PM
DDPJ
Oct 1, 2015 10:56 PM
