Ok, I searched first
Old Jun 4, 2009 | 09:32 PM
steve5140's Avatar
steve5140
Lots of info in the tech section and I can't believe how many people ask about a dropped oil pump shaft. Anyhow here's my story of wo.
Picked up a reubuilt 351w and drop it in a 81 f100. Did not know anything about the engine except it looked rebuilt. New pan, new timing set, all the plugs pressed in looked new.
Anyhow got the engine in primed the oil pump and fires it up. Heard some ticking in valve cover and shut it down. Put a mechanical gauge on and turned with a drill. No pressure and no oil out of pushrods. Lifted engine pulled pan and replaced oil pump (the one on it was brand new) cleaned screen and put back together. Got oil to fill line of gauge but not enough to register and no oil to top end.
Before I pull enigne out and back on the stand what can I check while in the car. If I pull the intake and check for oil in valley what will I be able to do if none. While I had pan off, everything under looked brand new so I don't think it was not rebuilt.
I did see a post about a missing plug in the valley but searched for it later and could not find.
I also dropped the oil shaft into the pan but it was standing up and was able to get it out with a magnet. When cleaning the pan I saw that little ridged washer and wondered what it was for. After reading the other posts I now know.
Old Jun 4, 2009 | 10:38 PM
Franklin2's Avatar
Franklin2
How much resistance do you have when turning the pump shaft with the drill? If everything is right, it should really load the drill down.
You could also unscrew the oil filter and see if the oil comes out of it while turning the pump.
Old Jun 4, 2009 | 10:53 PM
johnboy427's Avatar
johnboy427
Make sure your drill is in reverse the dist turns counter clockwise. Just thought I would throw this out there I have seen it done wrong.
-Johnboy
Old Jun 5, 2009 | 08:09 AM
steve5140's Avatar
steve5140
Turned the drill counter clockwise and there was a load on it. I will try the oil filter next and get back.
Old Jun 5, 2009 | 08:33 AM
dustybumpers's Avatar
dustybumpers
got any oil comeing out of the bell houseing? there is a freeze plug on the back of the cam that could be missing.
Old Jun 5, 2009 | 08:36 AM
dustybumpers
sycostang67 is haveing the same prob, his thread is called I think I'm done. you may want to pm him
Old Jun 5, 2009 | 10:36 AM
steve5140's Avatar
steve5140
I read his post already and working through it. Heres the update. Took the fitting off the engine for the mechanical ggague and got oil there then took filter off and got oil there. WHere should I check next? Where does the flow go after the filter?
No oil leak anywhere?
Old Jun 5, 2009 | 12:20 PM
dustybumpers
through the crank, then through the cam bearings. pop off your valve covers, pull the dist and take your electric drill in reverse, and turn the oil pump shaft. oil should come out of the push rods.put the oil filter and sender back on first or you'll have a mess. I'm thinking cam bearings installed wrong, holes not lined up. see if you have oil to the top first before you do anything else
Old Jun 5, 2009 | 12:40 PM
uncle.stosh's Avatar
uncle.stosh
I just posted this in Dan's thread as well:
the continuing saga of the mystery 351 windsor engine - THE H.A.M.B.
Old Jun 5, 2009 | 07:49 PM
steve5140's Avatar
steve5140
Sounds like the problem. I know I'm already not geeting oil to the heads. It appears the cam bearing are installed wrong. I was just trying anything before I pull engine out.
