4.6L swap into 89 f150 (F-STANG project)
#46
#47
on
I think the speed sensor is incorperated into the speedo cable on that truck is for the cruise control. Is there a connector on the speedo at the x-fer case?
Even if it is to control the tranny you wont be using the old ECU so it would be redundant. The main concern is that the new ecm has speed signal from the new tranny. That is a separate system from the speedo. Am I misunderstanding something?
Are you using the tranny from the 97? I know you're keeping your x-fer case. Can you post a link to your thread? You know the old tranny wont bolt up to the 4.6?
#48
#49
#50
"The donor truck is also a 4x4, so it had the speed sensor in the xfer case, the one that is exactly like the one in my '91 but the hole for the cable is plugged. Now, whether the '97 ECU gets it's speed signal from this sensor, or from the one in the rear-end, I don't know. I'm gonna hook up the one in my existing xfer case to the '97 ECU and see what happens."
I'll look that up in ALLDATA for you tomorrow, i'm almost certain that the 97 tranny uses a combination of input and output shaft speed sensors that are gonna send info to your new PCM. I call it this because it controlls the engine and transmission. It uses all sorts of info from the engine such as ECT, TPS, Load % calculation to determine shift points. For example with your 97 computer you could run that motor and trans in a Volkswagen bug. What i'm trying to say is that your new powertrain has no reason or need to communicate with your old computer. The speedo cable will only run the speedo, the connector goes to the old computer which you dont need anymore. The new trans has its own sensors. Being a transition year (97) i could be completely wrong. I'll check for you.
Hows it coming with your install otherwise?
#51
I put the 3.73s in tonight and it really woke this old girl up. Its much quicker now. I had the speedo up to 110 in a matter of a few short seconds, but who knows how fast im actually going. Even if it was 60-70 mph 0-whatever was very quick. I'm gonna say that it will blow and stock 351 away by a very long shot. (Sorry guys, i said it) I got a friend with an 02 mustang gt and we're gonna run them so I'll let you know how it fares against him. I live in holbrook, only a town over.
#52
I haven't been keeping up with this thread like I should and my internet won't let me just "cruise", so I don't want to try and ready through every page. I'm just wanting to know if this 4.6L is stock? I thought it was, but you make it sound like it's a real beast! This is a very exciting thread. You should enter your truck in a few magazines.
#53
#54
For some reason I thought that 4.6 was out of a truck. Oops!
Thanks Chris
#56
That's what I call "fun" horsepower. Keep in mind it's a small V8 that normall makes 210 horse and 280+ tq. He can always turbo it!
He will probably get decent fuel mileage too. I bet it won't be any worse than what the 300 gave. So no matter how you look at it, it's impressive, just because it's different. Yes, it's not a HUGE AMOUNT of POWER, but it's all very very cool!
#57
on
#58
Yeah its not THAT much, but it should be slightly faster than a stock gt mustang on paper. Given it has the same engine, and tire size. A stock mustang is slightly lighter but they also have 3.27 gears whereas i have 3.73s now. We shall see
I know that, I said I was gonna hook up my old *speed sensor* to the '97 ECU. It's got to get a speed signal from somewhere, it's either coming from the xfer case mounted sensor or the one in the rear-end. I am betting the one in the '97 xfer case and the one in my '91 xfer case are the same signal output.
It's gotten bumped down the priority list. I still need to work out my motor mount strategy, right now I want to try something with the truck mounts and see if it will work before I start cutting up the perches to match what you did.
With my truck, the RABS still functions properly its not incorperated in the trucks computer its got its own system. Hope this helps
Are the truck mounts close? Dont they bolt in on one side with 3 bolts or something weird like that? whereas the car had a stud on each side? I may be able to dig up some stock but not very good truck mounts if you wanna use them as mock ups or whatever, Let me know. Good luck man.
#59
yeah, it may not be a 10 second in the 1/4 mile truck, but im sure its enjoyable. i work on two cars with the 4.6 quite frequently (99 grand marquis, 04 mustang gt) and they both have no problems getting up to speed. The nice part about the 4.6, is that it keeps making good power till around 5000 rpm or so
#60
on
The thing that makes it a bit tougher is the driver's side cup sits 1" farther back towards the firewall than the pass. side. So I need to set the motor down on the mount/cup assy., then get underneath on the lift and attach the transmission and line it up side to side with the rear mount to make sure it's not canted to one side or the other. Then I can mark where the cups should sit, take the trans out from underneath, and then pull the motor out so I can bolt or weld the cups in place.
I will be taking pics of the mounts if this works because, if it does, I think this may be the easiest setup to replicate for someone else.
