Sponsored by: Auxito
Oil usage
Old Jun 3, 2009 | 09:19 PM
dantsg's Avatar
dantsg
Lightbulb Oil usage
How much oil are you using in your 5.4's? Mine with now over 180k is using about a quart every three weeks. No smoke or burning, did a tuneup while back and plugs were in good shape. Just wondering what everyone else is seeing.
Old Jun 4, 2009 | 11:15 AM
KingRanchMan02's Avatar
KingRanchMan02
How many miles do you travel in three weeks time? Ford says that a quart every thousand miles is considered normal. Good luck!
Old Jun 4, 2009 | 11:20 AM
dantsg's Avatar
dantsg
it varies but average would be about 400 a week.
Old Jun 4, 2009 | 11:32 AM
KingRanchMan02
Fits in the normal consumption category.
Old Jun 4, 2009 | 11:45 AM
greenego's Avatar
greenego
I don't see where that much oil consumpsion could be considered normal. If he changes his oil ,say, every 4000 miles he would be going through 4 extra quarts of oil between changes. That's hardly normal. My 5.4 with 76000 miles on it is still on the full mark of the dipstick after 4000 miles. I guess my engine is abnormal.
Old Jun 4, 2009 | 12:04 PM
Larry_the_handyman's Avatar
Larry_the_handyman
Yeah, 400 miles isn't even close to 1000. After 4000 miles, you'd have gone through 10 quarts. Have you done a compression test?
Old Jun 4, 2009 | 01:12 PM
KingRanchMan02
He said 400 miles is his average mileage per week. That means 1200 miles per quart and is as per Ford Motor Co, considered as normal. I didn't say that is what I have experienced just that it is acceptable by their standards. I would suggest to change the PVC valve and to be sure to use the specified weight of oil, 5W-20. Good luck!
Old Jun 4, 2009 | 01:13 PM
galaxie641's Avatar
galaxie641
400 per 3 weeks is 1200 miles, quite normal.
Old Jun 4, 2009 | 03:22 PM
greenego's Avatar
greenego
dantsg, what brand and weight of oil are you currently using?
Old Jun 4, 2009 | 03:23 PM
greenego's Avatar
greenego
Old Jun 4, 2009 | 03:53 PM
dantsg's Avatar
dantsg
10w-30 quakerstate
Old Jun 4, 2009 | 04:35 PM
fireball 440's Avatar
fireball 440
If that is considered normal then why even bother changing the oil, just change the filter every 4000 miles and the oil gets replaced anyways under "normal" operation. Personally I have had 2 4.6's, the '97 used about a quart every 5000 miles (synthetic) and the '03 doesn't use any oil at all. My Grand Am uses a quart every 1000 miles and it drives me nuts!
Old Jun 4, 2009 | 04:36 PM
fordmerc's Avatar
fordmerc
I know it is not a 5.4 but the 4.6 in my 97 f150 with 155K miles uses about 3/4 of a quart in 5k miles.That is using mc 5w30. The 4.6 in my 02 mountaineer with 82K miles uses about 1/4 qt in 5k miles using mc 5w20. Just to use as a comparison.
Old Jun 4, 2009 | 05:49 PM
steve(ill)'s Avatar
steve(ill)
change the PCV valve.
