I've changed all the u-joints in my rear drive shaft but already need a new one. What is a good heavy duty joint that I get to replace the factory stuff and where do you get them? I have the six speed tranny but am not a rough driver ad don't really put a heavy load behind the truck very often so I think I should get more than a year out of the u-joints. Thanks.
That's very strange. They probably weren't installed right or it was defective.
What happens is that the caps are pressed or pounded to tight to the end of the joint. Causes premature wear. I don't even fool with them anymore unless it's an emergency. As stated above if you lose a needle same thing happens. You are using grease-able u-joints I hope. If not, go in that direction and keep em greased.
I've just used factory replacement joints until now. I used to have a problem with the rear u-joint on my Jeep but I snatched the gears pretty good in it. I replaced the factory stuff with Spicer units and didn't have anymore problems. Just wanted to see if anybody used the Spicers on a Super duty.
It is also really important you drive shaft is put together in the correct alignment. I agree to tight, not enough grease, but if its out 1/4 turn at 1 joint, you will have severe balance issues and should notice it when driving? Just a thought. I have not ever done a ujoint on a SD and I have a total of 170k miles on two so far. So, it seems strange you have lost several. On older trucks I have used a greese pencil to run alignment marks through everything taken apart. If you are out now, it might be good to have a picture from one which has not been taken apart? Just some thoughts.
