Leaking 9"
Old Apr 16, 2002 | 05:47 AM
DeenHylton's Avatar
DeenHylton
Leaking 9"
Old Apr 17, 2002 | 11:51 AM
KJKozak2's Avatar
KJKozak2
Leaking 9"
Greetings all,
I just rebuilt my 9" and I have a leak. It's leaking from a crack in the axle housing which I intend to weld and grind down. Do the studs come off of the axle housing? I don't want to wreck them with the grinder.
It's also leaking from where the pinion gear comes out (behind the yoke). Is there a seal in there that needs replacing? If so, what other parts have to be replaced when I take that apart?
Thanks in advance!!!
Kevin K.
