I think the smaller intake ports are normal. Later setups, like my highboy's 390 with C8 heads and edel intake, the intake ports were smaller than the head ports.
As long as the head ports are larger than the intake ports, you're OK. Some would port-match the two.
But before you do anything, wait for others here to respond.
I looked at opening up the ports on the manifold, and it looked like I would end up with a 1/8" to 3/16" outside lip when it was done...seems a little to thin for me..but I'm not an expert on tolerances.
If you hold an intake gasket up to the intake, and to the head, are the intake ports smaller than the head ports on all sides, or just the bottom? If it's just the bottom, I wouldn't bother doing anything, especially at only 1/4" difference. That's supposed to be that way, it keeps the intake charge moving at a good speed and it helps it to travel into the head better.
On the other hand, you could port match it. But then, it's a truck.
