1978 - 1996 Big Bronco
O2 sensor after Removing Cad. Converter, Help please
Old Jun 3, 2009 | 04:41 PM
Elmer666's Avatar
Elmer666
What do I do with the o2 sensor after I remove the cadillac converter to install true dual exaust with glass packs. 1991 Ford Bronco 302 EFI.
help me please!
-elmer
Old Jun 3, 2009 | 05:29 PM
greystreak92's Avatar
greystreak92
Welcome to FTE and the Big Bronco Forum, we will endeavor to get you the most accurate info we can.
Put it back! It needs to go into the crossover pipe. Then the exhaust can split again and run dual. Not running it this way will give you odd O2 sensor readings that will most likely generate fault codes and alter fuel-air ratios caused by the inaccurate readings. The inaccuracies will cause a "lean" condition that will lead to poor performance and premature spark plug failure.
Old Jun 3, 2009 | 05:35 PM
g_k50's Avatar
g_k50
reinstall it, elmer. use a crosstube
Old Jun 3, 2009 | 07:30 PM
Kemicalburns's Avatar
Kemicalburns
why are you running duals? mandrel bent Y pipe or bassani y pipe with hi flow cat and run single exhaust. it will be cheaper and perform better.
Old Jun 4, 2009 | 12:01 PM
1Aauto's Avatar
1Aauto
Former Vendor
Hey Elmer,
I had an 89 Bronco that Headman full length hedders and flowmasters.It was loud and sounded great.Like the others said just plug the senser back in.
I ran my pipes out behind the rear tire and in front of the bumper one each side of the truck.That was a nice setup. The Mustang sets off car alarms.LOL
Old Jun 4, 2009 | 12:17 PM
g_k50's Avatar
g_k50
Setting off car alarms with your Mustang exhaust is not LOL, it's juvenile
Old Jun 4, 2009 | 12:20 PM
1Aauto's Avatar
1Aauto
Former Vendor
Ah.... I was kind of kiddin around.I obviously don't spend my time doing that.
Old Jun 5, 2009 | 12:23 AM
Elmer666's Avatar
Elmer666
Thanks for the Help
I will keep the O2 sensor and just run a single glass pack after the y pipe.
-elmer
jthesby
65
Mar 27, 2016 02:13 PM
dvotion
Oct 17, 2012 03:48 PM
supersugar
2004 - 2008 F150
Oct 15, 2010 06:33 PM
hugger94
1997 - 2003 F150
Apr 27, 2004 10:40 PM
