rearend mystery
Old Apr 9, 2002 | 05:35 PM
Kamikazee's Avatar
Kamikazee
rearend mystery
A couple months ago I bought a trailer load of frontends and rearends off this guy.I have one rearend I need some info on.It looks like a 3/4 or 1ton rearend(srw).It has the plug, wire, and sensor for ABS. I got the matching frontend also, or parts of, its independent.I have the tag off of the rearend and am not quite sure how to read it all.
Heres the tag info.
2 v131c
4L10 10 2 7K22
As far as I can tell its a 4.10 gear and I think its out of an late 80,s truck.Any help on the front would help also. Thanks ED
Old Apr 9, 2002 | 06:13 PM
Lightning2Fast's Avatar
Lightning2Fast
rearend mystery
well its definitely a locking rear with 4.10 gears. and its definitely a ford rear and not a dana. id say is a ford 10.25in rear.
Old Apr 10, 2002 | 01:22 AM
the law's Avatar
the law
rearend mystery
It's a Ford (Sterling) 10.25" Full-Floating Axle. It's a Limited Slip with 4.10 gears. I would guess it's out of an '87.
The Law
Old Apr 10, 2002 | 05:54 AM
rabidranger's Avatar
rabidranger
rearend mystery
10.25 it is, with 4.10 LIMITED slip, not locking. I don't think Ford ever sold lockers in any diff.
Old Apr 10, 2002 | 02:00 PM
Kamikazee's Avatar
Kamikazee
rearend mystery
>'87.
>The Law
Thanks everyone for the feedback.One more small question,what on that tag designates say the years,ratio, and open or L.S.? This way I can learn to tell what the info on the tag is by myself.
ED
No big chicks,just big tires!
Old Apr 10, 2002 | 09:45 PM
orange peel's Avatar
orange peel
rearend mystery
hey kamikazee, if its in good shape, how much do you want for that axle?
Old Apr 11, 2002 | 01:07 AM
the law's Avatar
the law
rearend mystery
Here's the break down on the Ford tag. I've found that Ford generally follows this setup on the codes, but not always.
Your tag said:
2 v131c
4L10 10 2 7K22
I'm not sure what the top 6 digits are, possibly a factory code? The 2 could mean it was manufactured in Canada, but I don't guarantee it.
The 4L10 indicates 4.10 gears with a limited slip. The L in the middle indicates Limited Slip. If it had a space (4 10) it would be a regular open diff. If it were 3.73 gears with a LS, it would read 3L73. I wanted to provide a second example just for safety's sake. The next digits, the 10 2 indicate the 10.25" ring gear axle manufactured by Sterling exclusively for Ford. Later in the 90's they switched to a 10.5" ring gear, and so those diffs have a tag that says 10 5. I don't know for a fact that 7K22 indicates when the diff was manufactured, but on my '89 the last 4 digits start with a 9, and on a '96 10.5" I looked at last summer they started with a 6. I would guess then that the 7K22 indicates an '87 axle. It couldn't be '77 as they weren't made then, and it couldn't be a '97 as by then they'd switched to the 10.5" ring gear.
The Law
Old Apr 12, 2002 | 08:47 PM
Kamikazee's Avatar
Kamikazee
rearend mystery
>for that axle?
Well I am not quite sure yet.I need to pull the drums and rear cover to see the condition it is in.Proably somewhere between 350 and 500.
No big chicks,just big tires!:P
Old Apr 14, 2002 | 07:54 PM
orange peel
rearend mystery
when you find out about the condition and all give me an e mail mgbgt00(No Email Addresses In Posts!)
thanks
Old Apr 17, 2002 | 07:59 PM
orange peel
rearend mystery
Old Apr 18, 2002 | 10:08 PM
Kamikazee's Avatar
Kamikazee
rearend mystery
Sorry, I havent got a chance to tear that rear apart yet.I didnt forget about you, just been busy,
ED
Old Apr 19, 2002 | 06:28 PM
orange peel
rearend mystery
alright, thats cool. dont want to hurry you along or anything.
Old Apr 19, 2002 | 06:38 PM
jlankf1's Avatar
jlankf1
rearend mystery
restoringmy46
Dec 3, 2011 06:33 PM
a1bummer
Apr 22, 2006 04:12 PM
capnkirk13
May 8, 2004 06:46 PM
STEW
Jan 11, 2004 07:30 PM
