Engine help!!!!!!!!!!!!!!!
Old Jun 2, 2009 | 09:36 PM
jesuscowboy's Avatar
jesuscowboy
I have a 92 with 351; I removed the emissions stuff and was in the process of putting on headers when I broke the last bolt. I tried easeout and broke it so now I'm tearing it down to take the head off so I can drill it out. Before I started this the compression was 130-135 on every cylinder. Now that I'm pulling both heads. Figure since I got to replace one head gasket I should change the other. What do you guys think I should do with the heads: take them to the shop or just fix the bolt and put heads back. I plan on checking for cracks and checking head to see if it's flat. But beyond that should I do anything else. This is my daily drive so I need to get it running asap. But now that I'm this far into it and going to have good heads going back on should I worry with the bottom half? Kinda worried about timing chain also basically convince me to leave this thing alone before I rebuild the whole thing.
Old Jun 2, 2009 | 09:43 PM
Conanski's Avatar
Conanski
What kind of miles are on the motor?
Old Jun 2, 2009 | 09:46 PM
Old93junk's Avatar
Old93junk
If you can get a die grinder or even a dremel with a carbide burr tip, you can get in there and grind out the broken bolt. Then its just a matter of seeing if you still have enough good threads or if you need to heli-coil the hole afterwards.............Save you a lot of work, unless you really want to pull those heads..........I have never surrendered to a broken bolt yet!
Old Jun 2, 2009 | 09:54 PM
jesuscowboy
Have no idea bought the truck couple years ago used it for work just recently I sold my daily drive to convert this into my daily driver. The odometer says 216000 but have to believe motor had some work to pull compression numbers like it did.
kentajeff
25
Apr 20, 2015 02:25 PM
austinlibke
Sep 28, 2013 06:52 PM
sherLocke9
Dec 18, 2010 10:24 AM
Matt300ZXT
Dec 19, 2008 05:33 PM
C-Leigh Racing
Nov 14, 2008 11:01 AM
