Ok guys Im new here, this is my first thread and Im hoping for some good help. When cruising down the highway at speeds between 50mph-70mph my rpm's will randomly jump up 200rpm-300rpm. If anyone knows what could cause this or has experienced a similar problem please fill me in. Now mind you it will not do this at any other speed.
I replaced the sensor in the rear end about 2 weeks ago and it still does it. Cruise control will not work for any more than 1 min before it deactivates. I did not do the tranny my self but it was done in february 09 w/ new TC I understand it could still be a posibility though.
its a 97 powerstroke
Auto e40d
k&n intake
3in down pipe to 4in straight pipe
4in skyjacker lift w/35in procomps
Thanks i will look into the bulbs and fuse to figure out the cruise problem. If any one has any more ideas about the RPM Variation though that would be great cause it occurs when cruise control is off also. I am gunna bring it back to the tranny shop and have a word with them about the TC cause it was supposedly replaced with the tranny but we all know how hard it can be to find a honest person now a day. I knew I should have just done the job myself but work and shcool kills all my spare time.
97 F-350 7.3
Auto
K&N Intake
3in Down pipe to 4in straight pipe
4in skyjacker lift w/ 35in Procomp Xtreme A/T
Alright, im off to the store right now. im gunna change them out then run it down the highway to see wat happens. ill post my results later this afternoon. THANKS
Well i changed the bulbs back to OEM then went and ran it up and down the highway between 50 and 70 and my rpm never varied, also my cruise control worked perfectly fine. i really appreciate all the help and im sure ill be back for more. THANKS a lot guys.
