Ford Explorer O/D light flashing
Old Apr 10, 2002 | 10:10 AM
Alicia4065's Avatar
Alicia4065
I have a 97 Ford Explorer and the O/D light is flashing.
I checked the manuel and it tells me to have my
Transmission checked. It's not slipping, it's still going
into gear. Any thoughts.
Alicia
Old Apr 10, 2002 | 01:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Alicia,
The flashing light means SOMETHING is wrong with the transmission system. It could be the transmission itself, a sensor, or wiring.
If you can't tell any difference in the way it operates it probably is something minor. Don't let it go very long - minor transmission problems have a way of turning into complete rebuilds if they are ignored! :-staun
The only way to know is to use an OBDII compliant scan tool and read the code(s), then follow the diagnostic procedures.
Mark
Old Apr 11, 2002 | 09:25 AM
Alicia4065's Avatar
Alicia4065
Well, the bad new is I need a new
Transmission it's going to cost me about
$2900.00 and I really don't have that kind of money.
Alicia
Old Apr 12, 2002 | 05:44 PM
Mark Kovalsky
Unless you really trust them, I'd get a second opinion. A lot of shops will tell you that a new transmission is needed whenever the light flashes.
Mark
Old Apr 12, 2002 | 08:22 PM
Like M. Fords's Avatar
Like M. Fords
Old Apr 15, 2002 | 01:29 PM
jimandmandy's Avatar
jimandmandy
Post Ford Explorer O/D light flashing
That is way too much money. Is this the dealer price? I paid $1800 for a E4OD rebuild and cooler, incuding tax and all labor, on a 4x4 F-150.
The problem was torque converter clutch slippage, but at 116k, I decided to have the whole thing done.
Try to ask around for a reputable independent shop. Stay away from the chain that advertises on TV!
Old Apr 16, 2002 | 09:02 AM
Alicia4065's Avatar
Alicia4065
The quote I got was from the dealer. Well, I went and
picked up my truck and the light hasn't been back
on since and it's driving well. A co-worker of mines
seems to think maybe the o/d button was stuck because
that happen to his daughter. When it happens again
I will take it to a place that specialize in
transmissions. Anyone from NJ, that can help me where
to it.
Alicia
Old Apr 18, 2002 | 10:35 AM
MAHinton's Avatar
MAHinton
Alicia,
I'm not from NJ (KS, actually), but if there is an Ammco Transmission in your area, give them a call. Had a C6 rebuild there a few years ago, not a problem since. Looking at having another done, in my other truck, and in a 4X4, t'case and all to remove, it would be $800 in the truck, $450 carry in. Granted, your trans would probably cost more (newer, electronic, etc), but Ammco also has a warrenty, which I assume Ford does also.
Might be worth the look.....
Matt
Old Apr 19, 2002 | 09:40 AM
Alicia4065's Avatar
Alicia4065
Thanks, I will check out ammaco out. It's just
being a woman I get ripped off so much. The dealership
charged me $160.00 to look at it. So, far the
light hasn't been back on and still driving
like it should.
Alicia
Old Apr 21, 2002 | 08:40 PM
Mark Kovalsky
Since the light is out and it is driving well I'd leave it alone. If the light comes on again, then get a second opinion. False lights/codes are not unheard of.
Mark
Old Apr 22, 2002 | 03:31 PM
jimandmandy
Aamco are the people I warned you about. Good ones may exist, but the horror stories are endless. They talked a friend of mine into a transmission replacement on a Camry, and the problem turned out to be in the engine computer. He was stuck because he approved the work based on the faulty diagnosis! Please try and find a reuputable independent shop.
mchild
Sep 11, 2017 10:15 AM
bkeese
Jan 7, 2014 06:48 PM
Nichonj
Sep 9, 2009 09:03 AM
creolex
Sep 8, 2006 09:33 AM
shyaam
20
Nov 28, 2005 12:36 PM
