CCV filter
Old Jun 2, 2009 | 09:04 PM
Ponyboychris's Avatar
Ponyboychris
Originally Posted by Bigcat350
I looked at Chris's and Guzzles and used a combination of both and I really like it, ran it back a little past the rear end and I haven't smelled it yet.
And the pics are where????
Just bustin' your chops!
Old Jun 2, 2009 | 09:30 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Originally Posted by indyF-350psd
it goes back into the intake. thats why you need the 16 feet of hose. from the ccv to the canister then back up to the intake......
could you mount in the engine bay.? why so far away indyF ??
Old Jun 2, 2009 | 09:55 PM
Bigcat350's Avatar
Bigcat350
Chris I still can only get (DAILUP PIC PROBLEM)but Insight is almost here.
I have a lot of pics to show from all of the stuff I have been through.
Old Jun 3, 2009 | 05:15 AM
King0581's Avatar
King0581
If you can find room to mount it you could but about everybody runs it to the back so that it cant be smelled.
Edit: I see you were asking about the stealth kit, which returns to the intake, I'm guessing, but the above would still apply. Other than the smelling it part....
Old Jun 3, 2009 | 08:06 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
its not very far back. mine sits right under the drivers side door. youll have maybe a foot or two leftover but its better to have more than not enough. you have to route the hose up and over the brake cylinder to keep most of the oil in the engine but the fumes will still carry a little oil to the filter. then you have to route the hose back up to the intake so its not 16 feet each way more like 6.5 or 7 feet in each direction. ill go take pic so you can see. hang on......
Old Jun 3, 2009 | 08:30 AM
indyF-350psd
here is a picture of how you turn the ccv doghouse around. make sure you get new o-rings from guzzle as the old ones will be swelled and a sob to get back on....
more routing of the hose up and over the brake cylinder....
a side view for position familiarization.its located just under the drivers side door......
and what it looks like under the truck......
and one of my engine just for GP since i was out taking pics in the sprinkles......
SANDDEMON08
6.4L Power Stroke Diesel
59
Jul 31, 2018 03:22 PM
juvat97
May 8, 2011 11:11 AM
juvat97
May 6, 2011 08:33 AM
MoyockPowerstroke
Jul 17, 2009 07:46 AM
Talyn
28
Jul 7, 2009 08:28 PM
