mass air conversion
Old Jun 1, 2009 | 09:59 PM
96red4.9's Avatar
96red4.9
mass air conversion
ok so i've been reading on this subject and i can't figure out whether i can use mass air, harness', and ecu out of 95 and it work without modification. so do i go to the junk yard, pull the parts, put them on and go?
Old Jun 2, 2009 | 07:46 AM
Conanski's Avatar
Conanski
If your truck is a '96 and it's under 8500lb GVWR then it's already mass air, if it isn't then the answer is no, the wiring and computers are completely different.
Old Jun 2, 2009 | 10:59 AM
96red4.9's Avatar
96red4.9
my truck is a 93 bronco actually so i can't take a 95 mass air setup and put it on mine and it work?
Old Jun 2, 2009 | 03:02 PM
Conanski's Avatar
Conanski
95 to 93 is possible but it may not be a simple plug and play operation, you'll have to compare the wiring diagrams and connector types and move wires as necessary. If both trucks have the same engine and tranny combo then the swap will be pretty painless but the further they are apart the worse it gets.
Old Jun 2, 2009 | 03:15 PM
96red4.9's Avatar
96red4.9
awesome!! i'll try and find me a donor...i'm prettry sure i know where a 95 f-150 is and hopefully it'll still have the stuff and where can i find detailed diagrams like that? i have a haynes manual....would that be good enough or need to be more specific?
njtinman2
Oct 16, 2014 09:58 AM
boosted95
Jan 26, 2011 12:07 PM
abendx
Apr 9, 2002 07:17 PM
Will Stewart
Feb 11, 2002 07:49 PM
89bigbronco
Aug 11, 2000 10:15 AM
