Bypass Filter
Old Jun 1, 2009 | 07:48 PM
caseydudem's Avatar
caseydudem
Question Bypass Filter
Sorry guys I know this has been talked about before, but I cant seem to find the answer. I am installing a bypass filter on my truck, and I know you should use the ports right by the regular oil filter, but what are the size and thread on those ports. If anyone knows off hand then I wont have to take mine apart until I'm ready to install. Thanks
Old Jun 1, 2009 | 09:24 PM
clintbonnie's Avatar
clintbonnie
Most oil bypass system kits come with the proper fittings.. no need to buy additional. Or are you making your own kit.. ?
Old Jun 1, 2009 | 10:50 PM
SpringerPop's Avatar
SpringerPop
The pressure out size is 1/8" NPT
The return back in is 3/8" NPT.
See: http://springerpop.net/F350/images/bypass_hoses1.jpg
Pop
Old Jun 2, 2009 | 09:08 PM
caseydudem's Avatar
caseydudem
Pop
Thanks Marv thats exactly what I needed.
Now if I can find a 3/8 npt to 1/8 npt adapter. My kit came with all 1/8 npt parts. Thanks again
Old Jun 2, 2009 | 11:50 PM
SpringerPop
That will be called a "pipe bushing".
Pop
Old Jun 3, 2009 | 01:24 AM
orng1's Avatar
orng1
I'm going to have to go over and have you help me.
Old Jun 3, 2009 | 06:53 AM
mongo75's Avatar
mongo75
You can get just about any fitting you need at Lowes or Home Depot. Brass works fine.
Old Jun 4, 2009 | 07:55 PM
caseydudem's Avatar
caseydudem
Any idea what kind of pressure will run through these lines. I know its not the high pressure, but I cant remember off hand what the low pressure is? Thanks
Old Jun 4, 2009 | 08:05 PM
orng1's Avatar
orng1
40-60ish??? Never seen this trucks presure but that's what the big rigs run
Old Jun 4, 2009 | 08:20 PM
caseydudem's Avatar
caseydudem
Thats what I was thinking, just wanted to make sure. Thanks
Old Jun 6, 2009 | 02:31 PM
mongo75's Avatar
mongo75
Damn that high? I know when my line was leaking it sure didn't feel like 50 psi LOL.
Old Jun 6, 2009 | 02:35 PM
RussB's Avatar
RussB
What does this by-pass do ????? Whats the purpose ! First time I've seen a thread about it !!!!!! Thanks
Old Jun 6, 2009 | 03:15 PM
mongo75's Avatar
mongo75
It's purpose is to by pass the tranny cooler when the tranny is cold, so that the fluid gets up to optimal operating temp quicker. The only bad thing about it, which is a rare occurance- is that sometimes it sticks open and will keep the fluid circulating internally, and not through the cooler like it's supposed to. This will cause your tranny to over heat real quick, and some indicators (if you don't have your own gauge) are a puking dipstick, truck not moving, a temp light, and in some cases a LOT lighter wallet.
Old Jun 6, 2009 | 09:40 PM
caseydudem's Avatar
caseydudem
I think you may have missed something. I have been talking about a bypass oil filter not a bypass for the tranny cooler.
A bypass Filter is usually used for better filtration. You keep your original oil filter and add another. The original filter continues to do its normal job while the by-pass filter takes oil at a much slower speed and filters it a lot more. It helps to entend the life of your oil and keeps your engine clean. The big rigs use them a lot. It really helps especially if you run the expensive synthetic oils. I hope that helps
Old Jun 6, 2009 | 11:46 PM
SpringerPop
Even though it's off topic, it's important for Mongo to know that the transmission bypass valve opens as a function of higher-than-normal pressure in the output port to the cooling circuit for the trans, NOT temperature.
The only time that the bypass valve actually bypasses the output fluid directly back to the return port is when there is some kind of clog or other restriction in the cooler circuit.
In a healthy system, the bypass should never open. The only reason that temperature might ever have anything to do with this is if the truck is in SEVERE cold, the kind that actually gels the transmission fluid. That would cause a cooler restriction. But remember, that's SEVERE cold! Besides, it wouldn't un-gel the lines anyway.
We now return to our normally-scheduled discussion about engine lube oil filtering.
Pop
