changing rear diff fluid
Old Jun 1, 2009 | 07:26 PM
mfp4073's Avatar
mfp4073
Is the only way to drain the old stuff to crack the back cover? That would require a new gasket and didnt want to open it up if I didnt have to. See the refill hole, but not a drain. Am I seeing this right?
Old Jun 1, 2009 | 07:31 PM
dart7383's Avatar
dart7383
Some people use a siphon hose through the filler hole, but the best way is to take off the cover. There is usually no gasket there anyway. It usually has a bead of RTV silicone around the mating surfaces. I always like to take the cover off, so I can clean out any sludge that may have accumulated in the bottom of the diff. That said, sucking the old fluid out through the fill hole is still better than leaving the old fluid in there.
Old Jun 1, 2009 | 08:31 PM
mfp4073's Avatar
mfp4073
That works. Is it safe to use solvent in these rears without an additional friction modifier. I dont think mine is a locker/limited slip.
Old Jun 1, 2009 | 09:04 PM
Noble Lumpkin's Avatar
Noble Lumpkin
If it is not a LS you do not need the friction modifier. I don't know what you mean by solvent. If you use a good synthetic Gear Oil like Amsoil a friction modifier is not needed.
Old Jun 1, 2009 | 09:39 PM
mfp4073's Avatar
mfp4073
Solvent...meaning sludge removal of the gunk up in there!
Old Jun 1, 2009 | 11:20 PM
dart7383's Avatar
dart7383
I've used some brakleen around the gasket surfaces and on a rag to wipe the bottom of the diff off, but I would be leery of hosing everything down with any solvent. Probably just best to wipe out whatever you can off the bottom or other easy to get to spots. The biggest trick in this job is getting the sealing surfaces clean so you can put some fresh RTV on them and not get any leaks.
Old Jun 2, 2009 | 07:30 AM
NewportNic's Avatar
NewportNic
RTV with Synthetic Gear Lube
My parts guy recommended using a gasket rather than RTV with Synthetic. He said that the synthetic lube broke down the RTV. So I used a gasket, no leaks so far...
Old Jun 2, 2009 | 03:07 PM
smlford's Avatar
smlford
How often should this be done?
I have not heard of doing this before...
Old Jun 2, 2009 | 03:23 PM
seagull369's Avatar
seagull369
Weirdly, I used a gasket on my '94 and it leaked anyway. Mating surfaces looked smooth, I coated both sides of the gasket with oil and I followed the recommended torque pattern. Only way I could get a leak proof seal was to use the RTV (like the pan had when I took it off). BTW, if you do use RTV, make sure to follow the directions on the package to the letter.
Like dart7383 said, it'd probably be best to steer clear of using any solvents in there. Change the oil once you've driven around for a good long while so it's nice and warm, and use that rag if there's any junk that doesn't drip out. Change the oil again in 3k or so, if you think you've missed any of the goo.
Old Jun 2, 2009 | 03:30 PM
wtroger's Avatar
wtroger
I have used nothing but Rtv for years no issues, regardless of fluid type. Rtv will fill imperfections in sealing surfaces that a gasket can't even get close to.
Old Jun 2, 2009 | 05:15 PM
mfp4073's Avatar
mfp4073
Mine looks nothing like that!
Old Jun 2, 2009 | 11:38 PM
Noble Lumpkin
NewportNic, What breaks down the RTV is "Friction Modifier". Permatex just came out with a RTV that is not affected by this. I have not been able to find it in stores yet but it is on their site. It has some Green rings on the tube.
Old Jun 2, 2009 | 11:40 PM
Noble Lumpkin
I used brake cleaner on mine and then wiped it off the best I could.
Old Jun 2, 2009 | 11:41 PM
Noble Lumpkin
It could for about $150 or so.
Old Jun 2, 2009 | 11:43 PM
TS6034's Avatar
TS6034
Nice lookin diff cover!!
