1986 150 4speed gets nothing
Old May 20, 2009 | 09:43 PM
Urban Redneck's Avatar
Urban Redneck
Wasn doing anything under the hood. Inside lights and radio all had power. But not a thing was working up front. jumped it, and slowly started. Turned it off to gas up, and started right back up. Next moning Had to jump it again. Got new battery and still the same problem, but now i cant even give it a jump to turn on.
Old May 21, 2009 | 12:54 AM
hittman1422's Avatar
hittman1422
voltage regulator? selenoid? each are fairly cheap and are good to replace every now and then anyway... i have a regulator laying around if you want it... just PM me
Old May 21, 2009 | 05:27 PM
hittman1422
so....
...did you fix it?
Old May 23, 2009 | 10:37 AM
Urban Redneck
I put a new selenoid, it looked alittle different then the one that was on there, the post were smaller on the new one, but anyhow it didnt work, so iam gonna maybe try and clean the connection wires a little better. Are there any test i can do that will help me find the problem. Could it be the starter or something. I did this thing were you touch the starter post with a screw driver. I didnt work for me but i have seen it work on other trucks.
Old May 23, 2009 | 12:40 PM
cadunkle's Avatar
cadunkle
Solenoid is rules out if didn't crank when you jumped solenoid terminals. That also makes bad ignition switch or wire unlikely. Another test for that is jump 12v to the S terminal and cehck for 12v at starter terminal on the solenoid.. In any event, pull the starter off and hook it to jumper cables to test. Ground to bolt/flange and 12v to post, should spin. If not go buy a new starter.
Old May 23, 2009 | 12:54 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I seen a guy bench test a starter like that and took his pinky finger off!
Make sure you hold it good and keep your hands and fingers away from the bendix gear.
Touch the ground to the starter flange as the last connection!
-Enjoy
fh : )_~
Old May 23, 2009 | 01:10 PM
87 XLT's Avatar
87 XLT
When I had the same problem on my 87 Ranger I simply added a jumper between the positive battery post & the starter relay. No joy, it still would'nt crank.
Added the jumper from negative battery post to engine block & when it fired right up I knew the negative cable was shot.
Old May 23, 2009 | 07:27 PM
Urban Redneck
So I went out and put a new starter and still nothing. But then i remembered that the owner before put a toggle swithch under the dash, that runs to the negative on the selinoid. Pulled it out, and one the the wires had came off, put it bak and then fired the bad boy up! Thanks for everyones help.
Theres nothing like climbing under a truck on a hot philly street.
Old May 24, 2009 | 06:59 PM
FESuperDuty's Avatar
FESuperDuty
Check your ground circuit between the battery and the engine, and between the battery and the cab and frame. An easy way to do this is to hook a jumper cable to the negative battery post, and the other end to a good solid ground point on the engine. Do the same for checking the ground to the cab or frame.
I had a situation once where the ground went bad between the battery and the cab. The engine would start and run, but it ran very rough. Simply turning the radio on would kill the engine.
Make sure the connections are clean and tight at both ends of the cables. Also, check your positive cable to make sure it hasn't rubbed through the insulation and shorted against the frame or engine somewhere.
Old May 24, 2009 | 07:06 PM
Dean88's Avatar
Dean88
+2 on checking ground. My 87 would randomly die from time to time, and it turned out that the ground had come loose and if you hit a bump wrong it would lose connection.
Old May 31, 2009 | 07:25 PM
Urban Redneck
Today my positive post on the seliniod melted off. Both wires were hot Neg and Pos. About an hour before it started funny, the starter kept running when ever i put the clutch down. I diddnt even have the keys in, so i turned the key untill it started the motor. THe battery, selinoid, and the starter are new, The old selinoid had taller post and had spaceres for the wire connections. But everything else was the same.
Old May 31, 2009 | 10:03 PM
ctubutis's Avatar
ctubutis
Is this one of those Chinese solenoids from an auto parts store?
Old Jun 1, 2009 | 05:54 PM
Urban Redneck
Yup cheap auto zone! do you think that was it.
Old Jun 1, 2009 | 08:32 PM
ctubutis's Avatar
ctubutis
It's impossible to say for certain by remote; it could be the solenoid is merely where the
true problem is manifesting itself/making itself known. Those things should NOT melt in
normal operation; this tells me either the starter is drawing WAY too much power, OR
the contacts inside the solenoid are faulty and too much current is flowing through too
small of a conductor.
But, a lot of those Chinese solenoids have been failing in recent years, coulda been bad
production runs or sumthin'....
51PanelMan
Feb 15, 2012 01:29 PM
alabama96
Jun 10, 2011 05:31 PM
Blaster7Romeo
Apr 26, 2011 11:37 AM
shamwowshammy
Oct 27, 2010 12:39 AM
sbjess03
1983 - 2012 Ranger & B-Series
Oct 26, 2010 02:07 PM
