Front End Pop!
Old Jun 5, 2009 | 01:47 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
ball joints don't typically pop or click
the just get loose and sloppy. then the steering tends to make the truck wander when you are driving around
easy test.
jack up 1 side of the truck and make sure it is safely up in the air
grab that tire and try to shake it side to side, and then up/down
if you get any play, then yes it's a bad ball joint. a good ball-joint doesn't allow any play
the IWE idea sounds pretty likely as well. especially as you mention the vacuum leak
btw, tell your Jeep buddy that the F-150 doesn't have constant velocity driveshafts like Jeeps do. if it ain't in 4x4, they don't spin
unless there is an error in the 4x4 system
Old Jun 5, 2009 | 07:55 AM
Fishin76's Avatar
Fishin76
When my 4x4 system was acting up this winter, I had some VERY large pops from it not engaging correctly. That was the IWE vacuum solenoid, (Man, was i glad that it was easy to change,)
Old Jun 5, 2009 | 09:49 AM
is300wrx's Avatar
is300wrx
I jacked up the driver side of the truck to see if there were any play. None. When I dropped it down to the ground, I wanted to see if it would wiggle.
The tire was able to move in and out with the truck being level to the ground. What does this mean?
BTW, thank you guys again for posting to my thread!
Old Apr 21, 2012 | 09:57 PM
slickfx4's Avatar
slickfx4
check your front axel mount bushings there are 3 of them
Old Apr 21, 2012 | 10:27 PM
ctsv510's Avatar
ctsv510
...this thread is 3 years old...
Old Nov 13, 2014 | 12:54 PM
dannyxc1128's Avatar
dannyxc1128
Exclamation 2004 Ford Explorer 4.6 V8 XLT
I having a similar popping noise, but only under hard acceleration... What could this be?
Dan
Old Nov 13, 2014 | 10:33 PM
Stewart_H's Avatar
Stewart_H
Dan
Your best bet is to present your problem down in the Explorer forum.
Stewart
Matthew Barnes
May 12, 2017 05:32 PM
Kicker456
2004 - 2008 F150
Nov 28, 2016 03:14 PM
MadWolf
Jan 29, 2016 07:00 AM
CountryMonkey07
Nov 20, 2015 07:18 PM
gearjammer69
16
Aug 4, 2014 09:57 AM
