new to forum I just got 05 f250 was wondering about the egr delete is this simple? cause it looks like anightmare. also if you do the delete what happens when you get it inspected im new to diesel so im sure this has been discussed before i do have4" turbo back looking to add s andb cold air intake and sct programer.
Since here in FL we don't have inspections, I don't know the details, but an EGR delete is visual, so you could bump in to troubles at an inspection. But it is true for the 4" turboback system without CAT in it.
If you are new to diesels, I recommend you to "suck" as much info in as you possibly can, here on FTE, and do the delete after you comfortable to grab the wrenches, and dig deep into your engine, because the EGR delete requires a lot of wrenching, and a good base knowledge about the 6.0 engine.
Also get an SCT - that's the best programmer, and the money you want to spend on an intake, spend it on custom programs instead. There is no need for an aftermarket intake, unless you go way out of the line, and try to build a dragster 6.0.....
thanks for the info im in tx so we dont have the tube in the pipe yet but still dont want to delete if its gonna cause problems later also what is zoodad
Before you do anything, a few hours of reading through the Tech Folderwill help. Most asked question article: Best Mods for my Truck is a good starting point.
