6637 containment system
Old May 31, 2009 | 08:26 AM
PSDLOVER's Avatar
PSDLOVER
Is there a good way to create a containment around the 6637? After many years/miles alot of crud is accumulating all over the firewall/fender area where all my electronic controls are located. I have been too paranoid to spray it down with anything. Would that be OK to clean there.
Old May 31, 2009 | 09:08 AM
Izzy351's Avatar
Izzy351
I clean mine there -- no issues after two years of it...
Old May 31, 2009 | 09:16 AM
bfife's Avatar
bfife
still plays with trucks
There is. problem is I can't remember the post. Somebody built a downloadable template for a 6637 cold air setup. works wonderfully. I built mine with this pattern. one could even fab up a top lid if desired. do some searching. or someone with a better memory than mine will chime in. Barney
Old May 31, 2009 | 09:26 AM
Izzy351's Avatar
Izzy351
Shoot Chris F350-6 a PM. I believe he either made the prototype for the template, or the template itself...
Old May 31, 2009 | 09:30 AM
bfife's Avatar
bfife
BINGO!! thats where it all started. Thanks Joe.
Barney
Old May 31, 2009 | 10:04 AM
cjfarm11's Avatar
cjfarm11
I to would like to find that template. If anybody could post a link it would be much appreciated! Thanks
Old May 31, 2009 | 02:35 PM
PaysonPSD's Avatar
PaysonPSD
Jim (Megawatt) built a beautiful surround for his 6637.
Where you at Jim?
Old May 31, 2009 | 06:02 PM
megawatt00's Avatar
megawatt00
Where you at Jim?
You Rang????
Old May 31, 2009 | 06:35 PM
F350-6's Avatar
F350-6
Mine's not as pretty as Jim's, but I quit once I had something that cut down on the drone that would happen at certain speeds on some roads. I got the idea from Brandon (bdrummons) & Chris (Rampage350), but got tired of waiting on them to get around to it (they got sidetracked ordering a different filter). Ron (ronspowerstroke) sent me some pictures and measurements of his AFEII cold air box, so I played around with it to make it fit the 6637. Marc (mudmaker) offered to help with the template work, so we put it into 8 1/2" x 11" pdf files so you can just print them off your computer, tape them together, and do this yourself.
Here's what mine looks like
Here's the link to Marc's post with the drawings https://www.ford-trucks.com/forums/7...ml#post5937371
There's plenty of pictures in my gallery of the parts & pieces. I tried to design it so it could be made with a pair of tin snips, some pliers, and a few pop rivets to keep things simple.
As for cleaning the area, just take the filter off or put a plastic bag over it and clean the area up. You'll also want to cover the alternator, powersteering pump lid, & clutch reservoir lid if applicable.
Old May 31, 2009 | 06:55 PM
jkidd_39's Avatar
jkidd_39
Jim, I love your cover! Very Very neat.
PaysonPSD's Avatar
PaysonPSD
Gentleman, you both did a good job. I have gone back to my AIS or I would be asking for some templates. If I go back to the 6637 I will know who to ask.
Old May 31, 2009 | 07:36 PM
megawatt00's Avatar
megawatt00
Thanks Andrew!
Thanks Robin One of these days life will be where it is supposed to be for me and I will make a few more boxes up.
Old May 31, 2009 | 08:22 PM
jkidd_39's Avatar
jkidd_39
I need a bright orange one now!
