rough idle on 390
Old May 31, 2009 | 06:47 AM
steve100's Avatar
steve100
rough idle on 390
hello I have a 76 supercab with a 390 that idls rough but smooths out to sewing machine smoothness going down the road. here is my list of things to check ; plugs ,wires dis cap, vacuume leak, and compression test for possible burnt valve or head gasket, if there is any thing else i should check please let me know for all of you know more about this than i do thanks for your help
Old May 31, 2009 | 10:59 AM
GA76Explorer's Avatar
GA76Explorer
Could be a choke problem i would check it out
Old May 31, 2009 | 11:51 AM
sc00ter's Avatar
sc00ter
burnt valve, compression, head gasket etc will make it run bad all the time. Start with checking ignition timing, checking for vacuum leaks, and carb adjustment. Good luck.
Old May 31, 2009 | 06:05 PM
montana1967's Avatar
montana1967
Personal experience from a past 390 owner. Put a carter 600 carb on and new distributor with dual points or a pointless dist. Check compression and do a leak down test. I brunned up a piston up before i got it right. Pluss it will improve performance and fuel mileage.
ZombiePopper
Oct 1, 2014 11:59 AM
Akmillman
Aug 5, 2013 05:53 AM
surfcraft
Mar 3, 2011 08:58 AM
miller_feed
28
Dec 10, 2008 08:46 PM
jwillyf150
2004 - 2008 F150
May 14, 2008 08:37 PM
