Sponsored by: Real Truck
Ball joints
Old May 30, 2009 | 11:17 PM
Greenlawnracing's Avatar
Greenlawnracing
Ball joints
I've heard a lot about them going bad on these trucks.
How can one tell when they are going bad?
I just looked in the service manual to see much work is involved with replacing one....it said that at the time of publication, it was not possible to replace the ball joints in a 2WD model. I'm assuming that isn't the case as I know I've already had one replaced.
Old May 30, 2009 | 11:40 PM
EXv10's Avatar
EXv10
Ford truck BJs do go bad soon. Jack the front up on one side and take a big lever like a 2x4 and have someone pry up and in on the wheel while you look at the joints. They can cause the truck to swerve when you hit the brakes, and cause a negative camber also. Get back and sight accross the front and back tires for a quick camber check.
Old May 31, 2009 | 01:43 AM
Greenlawnracing
The front tires are feathering.....would that be a sign of bad ball joints?
What exactly would I be looking for when I inspect them?
Old May 31, 2009 | 11:16 AM
EXv10's Avatar
EXv10
Any abnormal tire wear would be a sign. While performing the test above, look for movement at the joint. Rest a carpenters level against the tire, away from the bottom bulge, while on the ground, and if it has negative camber that is also a good sign. Stand way back and sight accross front and back wheels at the same time. Miles is also an indicater. Anything over 80k miles is too many miles.
Old May 31, 2009 | 02:30 PM
Greenlawnracing
No movement when I move the wheel. I do have 86K though
Old May 31, 2009 | 04:23 PM
Tom's Avatar
Tom
Is 80K all these things are good for?
Wow...new to SDs, but a bit disappointed by that.
Old May 31, 2009 | 06:02 PM
Greenlawnracing
Apparently so. I had one replaced about two years ago, and I found that the upper on the other side was bad today.
I'm going to tackle it with a friend in a few weeks.
I noticed there are several different types of replacement ball joints at O'reillys. Any one better than the other? I saw that the MOOGs are about $35 where the others are only $20.
Old May 31, 2009 | 07:08 PM
Tom's Avatar
Tom
I believe Moog balljoints have a limited lifetime warranty...
Old May 31, 2009 | 08:58 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Its mostly because they aren't greaseable. I think they would last a lot longer if you could grease them.
Old May 31, 2009 | 09:02 PM
EXv10's Avatar
EXv10
Moog should last longer since they are greasable. I think NAPA has them too. ETC ETC
Old Jun 1, 2009 | 01:57 AM
hotrodracer's Avatar
hotrodracer
Bought all four for my '05 SD for $125 tax & ship incl...
Tires were looking funny, alignment guy showed me l.front upper ball joint was going away. So being low buck, I just ordered Moog K80027 & 28's (if I recall correctly) to replace all four on my F350 c.cab diesel dually. Price was $125 + w/ Calif sales tax and free shipping for all four... Seller as Auto Parts Giant here in So Calif.
Also ordered 4 KYB Mono Matic shocks at under $60 each w/ free shipping from AJ Auto in San Diego.
Having a 2 post lift in my back yard should make installing the new b. joints and shocks, 'almost' easy... Then back to the alignment guy (Jon Lundberg, son of the renown drag race announcer) for a pro alignment...
Old Jun 1, 2009 | 10:37 AM
EXv10's Avatar
EXv10
You probably won't need an alignment but usually they will check it free.
Batgeek
May 24, 2011 10:30 AM
TinyWonder
Feb 16, 2011 11:07 AM
brian42
May 7, 2009 02:15 PM
Zcarbuilder
Aug 21, 2004 09:20 AM
broncopimpservice
Bronco II
Apr 13, 2002 09:57 AM
