1964 spedometer needle
Old May 30, 2009 | 10:30 PM
flipklos's Avatar
flipklos
Is just the spedo needle available as a part or does one have to but the entire assembly? Can one safely remove the bezel and needle and install a new needle?
Old May 31, 2009 | 07:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No parts of the speedometer were available separately.
What has happened to your speedo needle?
Has the reddish color faded away so it's hard to see? If so...go to the cosmetics counter of your local department store, pick out a color of nail polish, and paint it.
This also works for the gauge needles.
C1TZ17255E .. Speedometer Assy ~ Round / Obsolete
Fits: 1961/64 F100/1100 / 1965/66 F100/250 2WD/4WD Standard Cab / 1965/66 F100/250 4WD Custom Cab.
Fits: 1965/66 F350/800 / 1966/74 Bronco.
JST AUTOMOTIVE in Lebanon TN has ONE: 615-443-3086.
MILLER OBSOLETE PARTS in Binghamton NY has ONE: 800-546-7278.
DENNIS CARPENTER OBSOLETE PARTS in Concord NC has ONE: 704-786-8139.
ALCALDE AUTO PARTS in San Juan Puerto Rico has ONE: 787-753-1845.
BOB ALLEN FORD in Overland Park KS has ONE: 800-676-0675.
Old May 31, 2009 | 10:34 AM
dogbreath1000's Avatar
dogbreath1000
the needle can spin off the shaft..easy to fix..my spedo went to 90 and stayed there..presses the needle back on and lubed the cable...5 mile error at 60....beter than doing 5 sitting still..
Old May 31, 2009 | 10:38 AM
flipklos's Avatar
flipklos
I bent the needle up bad when I removed the dash plate to install my pertronix.
Looks like I am up a tree.
Old May 31, 2009 | 11:33 AM
dogbreath1000
my petronix fit under the cap....never thought to hook it up to the speedometer
Old May 31, 2009 | 11:46 AM
daveengelson's Avatar
daveengelson
See them on ebay occasionally. Purchased couple of extra instrument panels, only for the guages and speedo, believe I got them fairly cheap.
Old May 31, 2009 | 07:44 PM
flipklos's Avatar
flipklos
dogbreath, my ignitor is under the cap too. Just figured I would bypass the resistor wire like a mechanic not a hick. Where is your resistor wire located? In the tailgate?
Old May 31, 2009 | 08:31 PM
dogbreath1000
i got a hot wire going to my muffler so i can monitor the bearings there...
