360/390 temp sending unit location
Old May 30, 2009 | 08:48 AM
bicyclemonkey's Avatar
bicyclemonkey
I'm trying to straighten out everything with this motor. There appears to be a temperature sending unit directly on the thermostat housing and one on the intake right behind the distributor cap.
The previous owner had a second temp guage screwed into the bottom of the dash and the factory temp gauge disconnected.
What's the deal here? Why would there be two?
Old May 30, 2009 | 09:34 AM
montana_highboy's Avatar
montana_highboy
The factory sending unit is on the intake, he just ran a mechanical sending unit from the thermostat housing, i do the same, for instance your engine could be running anywhere from 180 to 210 degrees and the factory gauge is not accurate enough to tell you the true temperature and would probably not even move or at the very least only slightly, the only way to get an accurate reading is by installing a mechanical gauge.
Old May 30, 2009 | 11:23 AM
bicyclemonkey
So if I want to go back to the factory gauge is there supposed to be a plug for the thermostat housing after I remove the sending unit?
Old May 30, 2009 | 11:29 AM
montana_highboy
Exactly, you would just plug it if you don't want to use it.
PEZLO
25
Mar 8, 2017 01:06 PM
SoCalAngler
Modular V10 (6.8l)
May 25, 2016 08:13 PM
dvideo22
Bronco II
Dec 1, 2015 05:38 AM
parks911
General Automotive Discussion
Mar 5, 2006 03:39 PM
