Transmission Pan
Old May 30, 2009 | 07:24 AM
RA41126's Avatar
RA41126
Banned
Transmission Pan
Looking to change the fluid and filter for my 83 4.9L with I believe is the C-6 tranny. Autozone list 2 different filters, one for a shallow pan, one for a deep pan. How do I tell which one I have? I am having to change out the modulator and figured I would do all of it at once, as I am sure fluid will come out of the modulator when I remove it, correct? Also, what fluid, Type 'F' or?
Old May 30, 2009 | 07:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E5TZ7A194E .. DEEP Oil Pan-Use with 4WD
Fits C6: 1980/89 F150/350 & Bronco / 1980/83 F100's were not available with 4WD.
1977 and later C6 transmissions use MERCON. 1966/76 C6's use Type F.
Old May 30, 2009 | 07:39 AM
RA41126's Avatar
RA41126
Banned
OK, great! Shallow pan and Mercon. (Mine is an F-100). Reason I was curious is in the mid 90's I had an old '78 Granada with a C-4 that used type 'F', and wasn't sure if they still used it in the 80's model trannies. Thanx!
