radio problem i think
Old May 30, 2009 | 01:25 AM
pinto21632's Avatar
pinto21632
Question radio problem i think
i have a 95 explorer xlt i dont know if it is a ignition problem or what but my radio blinks as fast as u can blnik your eye when i start it or turn it to acc to listen to the radio then go to start it it will flash real quick when it does the time goes to 12:00 and i lose all programed channels driveing down the road it works great and it does not do it all the time only every so often and the radio is the only thing i seem to have a problem with its not a big deal but im tired of reseting the clock and the radio channels
Old May 30, 2009 | 11:32 PM
marragtop's Avatar
marragtop
Sounds like a wiring problem.
Old May 30, 2009 | 11:46 PM
liftnw8z's Avatar
liftnw8z
+1. There's an off chance that the radio might be going bad as well, but it really sounds like the issue's in the wiring.
Old May 31, 2009 | 09:19 PM
pinto21632's Avatar
pinto21632
i pulled the radio out today the wires seem fine but the antena the end pulled off the wire i think i fixed it i put it back on and used ele tape and taped it tight i will see if that fixes the problem would that make it do what it is doing like a bad ground throught the antena i know some radios use the antena as a ground on some radios ????
Obowersox26
May 16, 2016 01:47 PM
ag-ford-4x4
Electrical Systems/Wiring
Apr 24, 2009 05:12 PM
jcase321
Aug 28, 2006 09:34 AM
mzugg
Mar 31, 2005 10:08 AM
probablecause
Apr 23, 2004 10:49 PM
