300 just quit
Old May 29, 2009 | 08:03 PM
80fourd's Avatar
80fourd
300 just quit
I need some help bad. My 1984 F-150 300 carb 4 speed just died. It ran fine, leaks a little oil. I was heading up a hill in low RPM 4th gear and the motor quit. It died similar to when the valves are floated but it did not fire back up. It turns over like it has no fire but i just changed the distributor cap and rotor. I'm dumb founded about this. Coil? Fuel? Piston Rings?
Old May 29, 2009 | 09:20 PM
johnboy427's Avatar
johnboy427
Did it die like you shut the ignition off? I would check to see if it is getting spark before any thing else, and then I would move on to fuel. Ignition could be caused by coil, wiring, ignition module, or even a fuse.
-Johnboy
Old May 30, 2009 | 04:08 PM
80fourd's Avatar
80fourd
It quit as i was going down the road, do you know were i could find parts diagrams and/ or a fuse box map?
Old May 30, 2009 | 04:36 PM
Harte3's Avatar
Harte3
AutoZone.com | Repair Info
Try there.
Old May 31, 2009 | 07:42 AM
dustybumpers's Avatar
dustybumpers
how was it running before it died? do you have dura spark ign, or eec?.
Old May 31, 2009 | 05:36 PM
80fourd's Avatar
80fourd
Well it was running fine. I changed the fuel pump, coil, and ECM and still no spark
Old May 31, 2009 | 07:05 PM
dustybumpers
check your coil with a test light, with the key on, to see if you have power, could be a bad , or out of adjustment ignition switch. also test the fuseable links off your solinoid
orcatruck
British Columbia
May 16, 2010 05:46 AM
bmoyer
Mar 6, 2008 10:06 PM
matthew28337
Mar 26, 2006 09:55 AM
badboyblue
Modular V8 (4.6L, 5.4L)
Jan 3, 2003 01:21 AM
My toy for by
Jan 8, 2002 12:05 PM
