foil delete, not-so-bad (pics)
Old May 29, 2009 | 07:08 PM
surveyguy's Avatar
surveyguy
I did my foil delete today. I used airplane paint remover. I ripped off the foil and fur, and had to scrape some of the hair off for the stripper to work, but it sure did a good job. i used a plastic scraper, then added stripper once more. then i used a chore-boy (metal pots & pans scrubby) then rinsed clean.
only took less than 1/2 the can. $8 at wally world.
cleaned up the boot and installed.
hey, i have a "ding" on the other side of the pipe, does everyone's pipe have that little dent?
Old May 29, 2009 | 07:28 PM
Mark Buzzard's Avatar
Mark Buzzard
Very nice looking, I have the same task on my to do list.
Old May 29, 2009 | 07:35 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Yep, they come that way for clearance.
Old May 29, 2009 | 07:39 PM
surveyguy's Avatar
surveyguy
ah, kinda thought so. Hey Clay, take a peek at my other post, will ya? the one about the mark on the turbo wheel? Thanks!
Old May 29, 2009 | 07:54 PM
big poppa's Avatar
big poppa
Looks good, what a difference, good job. I had a bugger getting mine clean, used mineral spirits, terpintine, didn't have anything else on hand at the time.
Old May 29, 2009 | 07:57 PM
surveyguy's Avatar
surveyguy
yup, i tried everything i had at first when i had it out the other day, nothing touched it. that's why i picked up the can. i didn't know for sure if it would work either, sure did great. Oh, i got a little on my leg, and it started burning pretty quickly!
MSDS prolly says "Don't, just don't"
Old May 29, 2009 | 08:04 PM
big poppa's Avatar
big poppa
This seems like another good product to use to get that glued mess off of there, thanks for sharing..
Old May 29, 2009 | 08:14 PM
WA.Ranger's Avatar
WA.Ranger
I thought that the foil helped to keep the air going through the pipe cooler? Are we taking it off for just cosmetic reasons?
Old May 29, 2009 | 10:19 PM
tojoski's Avatar
tojoski
Its just a sound muffler, you'll get a little extra whistle with it stripped off.
Old May 29, 2009 | 10:23 PM
WA.Ranger's Avatar
WA.Ranger
I knew it did that, but I thought somebody posted on here about the technical reason it was on there? Oh well, might have to get that off of mine, sure is ugly........
Old May 29, 2009 | 10:45 PM
Bigcat350's Avatar
Bigcat350
Yea we all have that ding . Must have been a AH_CHIT by a engineer. Glad to see you found something that helps get that stuff off. I used some Toolroom mould cleaner on it and a hand held wire brush and it rolled off.
Old May 30, 2009 | 02:07 AM
surveyguy's Avatar
surveyguy
glad to help! i'm glad to share, i'm always so glad of what i learn here that i'm happy to have some things to share.
Old May 30, 2009 | 06:43 AM
new2diesel's Avatar
new2diesel
I did mine in Feb. and after I pulled off the insul. I used a propane torch. Burned the
adhesive off and used course steel wool to remove the scorched stuff. Then after that
I just kept using finer steel wool to polish it up. Went fast, looks good and I had everything here. Just the way I did mine not the only way.
Old May 30, 2009 | 03:43 PM
surveyguy's Avatar
surveyguy
great idea, had i thought of that, it would have helped to at least burn off the hair first.
Old May 30, 2009 | 04:57 PM
jdecker88's Avatar
jdecker88
Looks good man now just throw some paint on her .
