Transfer Case Doesn't want to shift..
Old May 15, 2002 | 07:36 AM
ButchWhitehouse's Avatar
ButchWhitehouse
I have a 1974 3/4 ton F-250 4x4, with a 390, C-6 and a divorced NP205
transfer case. In the past it's been a piece of cake to shift the
transfer case into 4 high, 4 low etc. Now it takes everything I can
do to it get it to shift into 4 anything or back to 2 high. Does this mean something bad or am I doing something different or wrong in my old age.....
Thanks,
1974 F-250 4x4
1996 F-150 4x4
1999 E-150 D'elegant Conversion
Old May 16, 2002 | 12:17 AM
proford460's Avatar
proford460
how long ago did you use it and what part of the counrty do you live in??????
Old May 17, 2002 | 07:08 AM
ButchWhitehouse
It's been a while since I had it in 4 wheel drive. Probably the better part of a year. I live in Southern Illinois, but moved from southern Michigan last year. It doesn't get much mileage on it anymore. I've never had it do this though. I had a rebuilt C-6 put in it last fall. Thanks for you reply and sorry for taking so long to respond.
Old May 17, 2002 | 01:18 PM
AZ4x4f150's Avatar
AZ4x4f150
check for rust build up on the linkage for the transfer case and the little plastic bushings they put in the transfer case linkage wear out from age and can make it hard to shift I would check those first
Old May 18, 2002 | 11:59 AM
MustangGT221's Avatar
MustangGT221
My dads f-250 is similar, bw13-56 with c6 and you can't put it in 4low because of the problem AZ4x4f150 talked about.
Primary rig is NOW TOTALLED :-X23 :
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
Some pictures in my gallery.
Then theres:
88' F-250 Superduty 351 + c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter. Top speed, 65mph, Go Baby Go!
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old May 18, 2002 | 09:37 PM
Cope's Avatar
Cope
aaroncmears
Jul 2, 2013 10:20 PM
1974F100
13
Dec 12, 2010 11:00 PM
icedog
1997 - 2003 F150
Mar 5, 2007 03:43 PM
Jimbo302
Jan 20, 2005 01:17 PM
mvollmer
Sep 2, 2004 08:31 PM
