Thottle Position Sensor Replacement
Old May 29, 2009 | 09:24 AM
nitecreate's Avatar
nitecreate
Question Thottle Position Sensor Replacement
The TPS in my 1996 is acting up periodically.
I ordered a new one. The new one that is suppose to be for this truck turns out to be quite a bit different, about the only thing that matches the old one are the mounting screw holes.
In researching, the dealer tells me that the TPS I have is obsolete and the only way I can replace it is to purchase the entire throttle assembly for the cost of $450.00. Has anybody experienced this problem and are there any suggestions as to solving it next to buying the complete assembly?
Old May 29, 2009 | 10:36 AM
Neal 97 250's Avatar
Neal 97 250
Salvage yard.
Or try fte-parts guy. He is one of our sponsors here.
Old May 29, 2009 | 02:28 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Where did you buy the sensor. Try here
https://www.dormanproducts.com/cgi-b...31&vtime=55531
Old May 29, 2009 | 07:49 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I've had to buy the pedal assy for a couple of mine, was cheaper at powerstrokeshop.com by quite a bit than the dealer. I belive their was a thread a while back about being able to get the sensor....
Old May 30, 2009 | 07:04 AM
dmptrkr's Avatar
dmptrkr
I think Ford changed the accelerator assembly in 96. The Dorman TPS shows applications for 96-97 only. It's possible you have the old unit even though your truck is a 96.
Here's an old thread with pictures of the newer assembly
https://www.ford-trucks.com/forums/8...ediculous.html
PaysonPSD
96
May 18, 2023 10:17 PM
Steve_250
Dec 30, 2013 03:20 PM
F250_
Jun 24, 2013 10:03 AM
79 bronc
Aug 5, 2011 03:40 PM
nitecreate
Jun 6, 2009 04:01 PM
