Need fuel system help quick!
Old May 28, 2009 | 08:08 PM
Sycostang67's Avatar
Sycostang67
Unhappy Need fuel system help quick!
I just put my motor in today(85 F-250, 460), and I have no fuel. I noticed some melted wires on a relay which I think is the pump relay. I replaced them even though it looked as though they had melted a long time ago. I tried resetting the impact switch, cleaned and checked all connections. I dont know what else to do. I checked the connections at the relays and there is no power to any of them. I would like to get this motor fired up and broken in before dark since I have snooty neighbors. All the fuses are good too. Everything worked perfectly 11 days ago when I pulled the motor.
Old May 28, 2009 | 09:03 PM
brett_d's Avatar
brett_d
check your grounds! That is very common when replacing motors. Make sure all the straps are hooked up.
Old May 28, 2009 | 10:18 PM
uncle.stosh's Avatar
uncle.stosh
Sorry Dan, I got nothin'.
It sucks when you get that far and go to fire it up and something stupid like that holds you up.
There is nothing like starting up a new motor for the first time.
Old May 29, 2009 | 12:05 AM
Sycostang67
I'm not sure If I just needed to prime it, but I bypassed the relay and got it started...and decided to get rid of the truck.
Old May 29, 2009 | 12:08 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Why?
-Enjoy
fh : )_~
Old May 29, 2009 | 12:10 AM
Sycostang67
I started another post explaining why.
