shift kit problems
Old May 21, 2002 | 11:34 AM
DoubleA's Avatar
DoubleA
shift kit problems
Old May 21, 2002 | 08:10 PM
78bronco's Avatar
78bronco
shift kit problems
i put a b&m shift kit on the heavy-duty setting, bolted to the trans, put fluid in, but the trans didnt work unless the engine giving lots of gas :-( could it be lose valve body bolts, low fluid, i screwed up.
Old May 22, 2002 | 11:50 AM
vanner's Avatar
vanner
shift kit problems
Did you make sure you got all the check ***** in the right place for your model year.The valve body bolts should be torqued to inch pounds if they arnt torqued right you might get fluid loss between the valve body and the seperator plate.If its none off these it might be debris from the rebuild one more thing make sure you removed all the old gasket material that also might cause a space for fluid to leak if fluid leaks between the valve body and main body you wont have enough pressure to shift the tranny.B&M has great tech help just give them a call.Good luck.
Old May 22, 2002 | 02:32 PM
78bronco's Avatar
78bronco
shift kit problems
how do you convert in/pounds to ft/pounds? is it just ##in/pounds divided by 12.
Old May 22, 2002 | 07:07 PM
78bronco's Avatar
78bronco
shift kit problems
got the shift kit to work, but after a while driving ont he highway or lots of city driving the first gear will slip a bit, or will bang into second
