Rear Diff Fill Question
Old May 19, 2002 | 03:18 PM
Pastmaster's Avatar
Pastmaster
I just changed the rear fluid on a 97 F-250 with the Sterling axle. Had no problem filling fluid with the fill/check hole. I tried to do the same on my 1993 F-150, except I could NOT get the fill/check bolt out. I filled the diff 2.75qts through the VSS hole. None of the fluid has leaked out on the ground, so I know it's somewhere in the diff. Am I okay using this method?
'93 F-150 loaded and modified!
Check my Gallery
Old May 20, 2002 | 11:52 AM
Ratsmoker's Avatar
Ratsmoker
I bet this is one of those times you wish you had tried to pull the plug before removing the cover right? If you have a good way to measure the amount of fluid going in and you are 100% sure of the capacity then it should be no problem. I have seen people fill trannies from the drain plug hole at the lube rack before when they couldn't get the fill plug out. This is something I would not recommend though.
Old May 20, 2002 | 12:25 PM
AZ4x4f150's Avatar
AZ4x4f150
you can get away with filling thru the vent tibe hole but make sure you know it is full and alot of times it will be a very slow process cuz the air needs to escapre while filling since you are filling thru the vent tube
Old May 20, 2002 | 08:40 PM
Pastmaster's Avatar
Pastmaster
Guys, My Haynes manual lists 2.75qts full on the 8.8" axle. I used 2 3/4 bottles of the fluid. I hope I'm at least darn close to the level.
Yeah, the fluid was still gold. If I knew I was going to go through this, I wouldn't have touched it. Oh well! Live and Learn! I appreciate the opinions!
Check my Gallery
Old May 20, 2002 | 09:41 PM
brown 4x4's Avatar
brown 4x4
[updated:LAST EDITED ON 20-May-02 AT 10:42 PM (EST)]Quick question: when you take off the rear cover to drain it, there's a gasket there that needs to be replaced, correct?
[font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old May 21, 2002 | 12:49 AM
Ratsmoker's Avatar
Ratsmoker
Most people I know use RTV instead of a gasket but yes something of the sort is needed.
Old May 21, 2002 | 11:47 AM
rabidranger's Avatar
rabidranger
[updated:LAST EDITED ON 21-May-02 AT 12:48 PM (EST)]Uhhh, if your book said 2.75 quarts for the 8.8 than you are going to need ALOT more for the sterling 10.25!!! I am thinking more like 4-5 quarts! Especially if it is a full-float, cuz the outer bearings are lubed by the diff oil.
edit:
my bad, I thought you were having trouble with your F250, not the F150. Nevermind....
Old May 22, 2002 | 07:45 PM
bisaksen's Avatar
bisaksen
Old May 22, 2002 | 09:20 PM
Pastmaster's Avatar
Pastmaster
Yeah the Sterling held 4.5quarts till it started over flowing. I was just wondering about the 8.8".
Check my Gallery
crivaro
2004 - 2008 F150
Apr 29, 2012 05:00 PM
paul64
1997 - 2003 F150
Mar 17, 2010 11:10 PM
mikren
1997 - 2003 F150
Sep 15, 2009 08:09 AM
thefnswits
Apr 13, 2008 05:40 AM
jjed2007
2004 - 2008 F150
Feb 21, 2008 09:50 PM
