need advice...
Old May 27, 2009 | 12:41 PM
Deon08's Avatar
Deon08
need advice...
I have a 08 f-150 king ranch 4x4. I bought it new and after 600 miles there was a hard vibration coming up into the dash when the transmission lagged before changing when accelerating at highway speeds. The dealership replaced the 4x4 shift motor and it went away. Now with 14000 miles there is a vibration more in the front end when on the highway. It seems to happen when the transmission lags before changing when accelerating. The sound coming from the front end is like the sound when you drive on the rumble strip on the side of the highway and can be felt in the pedal. Can someone please help me!!!
Old May 27, 2009 | 01:07 PM
bridge's Avatar
bridge
Sick 'n Tired
It sounds like it could be your 4x4 engaging. That sound might be your IWE loosing vacuum momentarily. The sound you describe sound like the common complaint of a bad IWE solenoid, I just never heard an intermittent complaint. Usually when they go bad you get that sound all the time.
Old May 27, 2009 | 03:32 PM
Deon08's Avatar
Deon08
If driven like this will it cause damage to other parts?
Old May 27, 2009 | 04:17 PM
bridge's Avatar
bridge
Sick 'n Tired
IF what a postulated is problem you can drive it for some time, although it's not altogether good for the 4x4 system seeing as the front shafts will be turning the transfer case.
Old May 27, 2009 | 04:52 PM
Ryan50hrl's Avatar
Ryan50hrl
get it back to the dealership...make them fix it
Old May 27, 2009 | 06:11 PM
Deon08's Avatar
Deon08
Thanks for the advice. Much appreciated.
battmanf16
22
Mar 11, 2020 11:36 PM
Barnyrad
Feb 20, 2012 11:37 PM
darkpurp1e
Feb 13, 2012 04:29 PM
darkpurp1e
Feb 12, 2012 04:23 PM
expo54bx
Oct 2, 2010 12:52 PM
