Sponsored by: Real Truck
window problem
Old May 27, 2009 | 11:37 AM
Curt Bates's Avatar
Curt Bates
window problem
On my 1997 F-250 XLT 4X4 EXT.Cab.
When I roll down the passenger window from the drivers side it will roll down but not roll up, you have to roll it up from the passenger control and now the drivers side window will go down but not up.
Is this a problem in the control switch on the drivers side door?
Old May 27, 2009 | 11:44 AM
BillyBob69's Avatar
BillyBob69
I would look at the passenger side. I had an older ford truck like yours and the circuit is set up that the passenger side is the primary. I popped the door panel and started tracing wires. Found two broke wires where it goes from the door to the fender.
