Problems With 4.9L Ignition or ECM??
Old May 27, 2009 | 10:16 AM
StankFord's Avatar
StankFord
I Just Got a 1990 f150 and it runs when it wants to. first you have to jump the 2 red wires on the relay under the hood. (the one with 2 yellows , 2 reds and a small black) then it will crank (sometimes). when it does actually fire up it runs excellent. someone said replace the wiring harness , another said replace the ECM. I'm not sure what the problem is but i do know that the original owner ran constant power to the fuel pump which tells me that the ecm or relays werent doing thier job. but the fuel pump is running and the coil has power but sometimes it just wont fire up. Any help would be great.
Old May 27, 2009 | 10:37 AM
wolfy's Avatar
wolfy
A very common problem on these trucks is the fuel relay will go back, which is probably why the previous owner ran continuous power to it. I would get a shop manual to help you diagnose problems and trace down the issue, instead of throwing money at it. I have rarely seen an ecu go bad. best of luck... let us know what you find out
Old May 27, 2009 | 12:09 PM
blkford95's Avatar
blkford95
I have a 1995 f-150 4.9L L6. it has 319K miles original engine and transmission. it has three speed auto with o/d and 3.73 rear end gears. what can i do to improve mpg?
n4ynu1010
17
Aug 4, 2012 09:05 AM
DKW 86
Jun 5, 2012 04:12 AM
kennyr
Jul 9, 2011 11:25 PM
whitetrash
Bronco II
Mar 27, 2008 05:29 PM
Traderjoe28
General Automotive Discussion
Jul 21, 2006 03:33 PM
