Replace ECM or simply short wire?
Old Jun 4, 2012 | 07:47 PM
DKW 86's Avatar
DKW 86
Some of yall have been helping out with my truck...
88 F150 XLT 4X4 5.8 Auto.
Original problem is that it runs so rich, @ low fuel pressure, that it can fill the crankcase with fuel in a few minutes.
Can not get my fuel pump to stay on. Replaced relay and troubleshot everything.
Seems that the only way to get the fuel pump on and power/pressure up is to short the tan/green wire that goes to the relay and also goes to the test connector.
Can i just short that wire, or do i need to replace the ECM. It comes from port 22 on the ECM.
Old Jun 4, 2012 | 08:44 PM
Conanski's Avatar
Conanski
Sounds like the injectors are locked open, what have you done so far?
Old Jun 5, 2012 | 04:12 AM
DKW 86's Avatar
DKW 86
Essentially working thru almost everything regarding the fuel rail. I just bought the truck for a song.
My major find so far: low fuel pressure and now loss of power to the pump. The ECM on the truck is a reman. It looks brand new. The fuel pump is OE, but can hold 40+ pressure when i short the tan/green wire to relay.
The ECM was not mounted correctly and was likely giving me an intermittent ground problem. The injectors were likely firing improperly too.
Today, after work, i will short the wire and see how she runs.
THE BLUE HEAP
19
Jul 27, 2016 12:59 PM
FlyTSI
Apr 20, 2009 04:31 PM
cjfaber
1983 - 2012 Ranger & B-Series
Dec 11, 2005 03:03 PM
fomocoloco1
Aug 15, 2004 09:09 PM
TryMe
Jan 26, 2003 10:24 PM
