1991 e4od T/C question...
Old Apr 6, 2002 | 12:59 AM
Phrappster's Avatar
Phrappster
I've read all the archived posts about my 1991 e4od transmission and it appears the shuddering/vibrations I get while driving are caused by the torque converter clutch slipping.
I lightly pushed the brake pedal while it was doing it the last few times and I could feel the converter clutch releasing and the shaking stopped!
I changed the fluid and filter and added some tranny conditioner a month ago and it's improved a lot.
My question is, what should I do to be sure the converter has to be changed? And I'm selling my van so I can buy an old ford truck and camper so I don't want to do more than I have to to this van.
Thanks,
Rod
Old Apr 6, 2002 | 12:07 PM
Lightning2Fast's Avatar
Lightning2Fast
canging the fluid was a good idea. but did you change the fluid in the convertor also? you should have drained all the trans fluid including the convertor. 7 out of 10 times this will fix the problem. but just dropping the pan and changing the fluid doesnt cut it. the convertor must be drained.
Old Apr 6, 2002 | 06:06 PM
Phrappster's Avatar
Phrappster
Thanks, I didn't know about the converter drain. I will try that before panicing!
This website rules!!!
Old Apr 7, 2002 | 07:25 AM
Lightning2Fast
like i said youve gotta do the whole service again. drain the t/c and drop the pan again. get all the old fluid out.
Old May 29, 2002 | 01:12 PM
leadhead's Avatar
leadhead
i am having the same problem with my 91 f-150, did draining the T/C fix your problem?
Old May 29, 2002 | 02:08 PM
RussF's Avatar
RussF
