Transmision front seal
Old May 26, 2009 | 07:43 PM
Lenster's Avatar
Lenster
Ok.. I have a 2003 f250 super duty 5.4 auto.. So I decided to tow for the first time my bobcat for a 3 hours up some steep hills on on the highway.. Just 150 yards from my destination the tranny started to leak and dripped on the exhaust and started a fire.. well good thing i was able to put it out..
After closer examination it seems the front seal let go.. But i needed the truck to get home so I put in lucas transmission seal. I have only 45k on the truck and changed my transmission fluid less then a year ago.. My ford guy said the lucas should work so far after the tow back home it is holding up.. Should I just replace the seal anyway to be safe??????? And or is there anything I can do to beef up the tranny...
Thanks
Old May 26, 2009 | 10:04 PM
Fomoko1's Avatar
Fomoko1
Welcome Lenster.
For help with your transmission question you can re post in the Super Duty And Heavy Duty forum: Super Duty And Heavy Duty - Ford Truck Enthusiasts Forums or the Clutch,Transmission, Differential, Axle and Transfer Case forum: Clutch,Transmission, Differential, Axle and Transfer Case - Ford Truck Enthusiasts Forums
Swing by your local NY chapter with your intro: New York Chapter - Ford Truck Enthusiasts Forums
Don`t forget to fill in the location field in your profile as well.
Ron Wellington
New Member Introductions
Dec 27, 2009 10:48 PM
bobquin
May 11, 2008 04:33 PM
WISESHTMETAL
Apr 24, 2008 03:09 PM
larrya150
Mar 11, 2008 12:32 AM
davidm54
Oct 13, 2007 02:05 PM
