E40d shudder and fix.
Old May 29, 2002 | 01:09 PM
wrenchhead's Avatar
wrenchhead
To all who have these things. I was having real bad shudder last week and hard and slow shifts. I didn't know what it was until I saw the messages on this board and realized I had a serious problem. So Monday I drained the torque converter through the hole provided and then dropped the trans pan and drained the fluid. I then refilled it with Dextron III. I know someone on this board said not to use this but use Dextron II. I'm not sure why the difference but anyway now the truck runs like new and I hardly feel the shifts and there is no more shudder. I don't know how long this will last but it's nice while it does. Woody
Old May 29, 2002 | 01:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You should be using MERCON fluid. Many fluids say MERCON and Dexron. MERCON is Ford's rating, DEXRON is GM's.
Mark
Old May 29, 2002 | 04:37 PM
DavidB's Avatar
DavidB
Mark is right. You should be sure that the fluid you use has the Ford Mercon rating. I think that the procedure you used was perfect. I have done this on quite a few late model Ford transmissions with the same problem and had excellent long term results. Good Job.
Old May 30, 2002 | 09:10 PM
FordMasterTech's Avatar
FordMasterTech
Most of the fluids that are Mercon-3 rated are also rated for Dextron III and vice-versa.As a matter of fact, the Motorcraft Mercon 3 also says Dextron-III on the bottle. Mercon 5 is a different fluid altogether and should not be interchanged for Mercon/dextronIII.
Old May 31, 2002 | 12:38 AM
BillyMac's Avatar
BillyMac
Post E40d shudder and fix.
