Sponsored by: Auxito
2002 idler arm change
Old May 26, 2009 | 02:34 PM
yesitwill itsaford's Avatar
yesitwill itsaford
Any tricks or speical tools to changing an idler arm on a 2002 FX4 4.6?
Old May 26, 2009 | 09:17 PM
papajoemrt's Avatar
papajoemrt
nothing more than the right sized socket/wrench to un bolt it from the frame and steering linkage and then to reinstall using a replacement idler arm by MOOG. the skid plate should be removed for very easy access to the idler arm.
a tie rod puller or other small puller could be used to seperate the joint end from the steering linkage. other than that it's a relatively easy job just check the rest of your steering components then get an alignment.
Old May 27, 2009 | 12:09 AM
yesitwill itsaford
Thanks so much for the info. This is really the first thing to go wrong with this truck, especially after doing a very thorough product testing for the past 7 years. I picked my screen name because I still have friends scratching their heads.
jetcom
New Member Introductions
Feb 12, 2008 01:02 AM
ZoomingM3
1997 - 2003 F150
Dec 6, 2005 08:30 PM
