Electrical / Battery Question
Old May 26, 2009 | 01:52 AM
Slamdunkpro's Avatar
Slamdunkpro
I'm having an issue where my Ex runs fine when started, but either cranks really slow or not at all (like the battery is way down). It will start if jumped. When it's running all the electronics function fine and there is no "fade out" as in the case of the alternator not charging. In fact I just returned from a 650 mile trip and except for the starting issue the truck functions normally. It's got a Motorcraft battery in it which I suspect is the original. The view dot on the battery is green, yet I suspect more and more that the battery just quit holding a charge. It's either that or there is a short in the system somewhere draining the battery with the key off.
Any thoughts?
Lastly what is the biggest (amps) battery I can get in the standard battery carrier on an Ex? ('05, gasser)
Old May 26, 2009 | 04:46 AM
Monsta's Avatar
Monsta
Sit. Stay.
I would definitely budget for a new battery. I just replaced mine (750cca) and it, too, was an 05. The "gauge" on it was green and actually still is as it's in my garage...but it sure didn't like trying to start my truck.
Old May 26, 2009 | 08:01 AM
ReAX's Avatar
ReAX
It's probably holding a surface charge, if you put a DMM on it will read in the 12.6 range, but if you turn the lights on it will drop way down. It wouldn't hurt anything though to verify that the alt is putting out 13v+ too.
Old May 26, 2009 | 08:33 AM
Rickx's Avatar
Rickx
Optima, Red or Yellow top batteries are the best I've found.
Old May 26, 2009 | 09:53 AM
ReAX's Avatar
ReAX
I believe Optima's quality is falling. I had one blue top that lasted 4 years, then I went through 3 more in the next 3 years before giving up on them. A lot of other brands are producing AGM spiral cell batteries, so far I am pleased with my Exide Orbital.
Old May 26, 2009 | 11:28 AM
EXv10's Avatar
EXv10
The Motorcraft battery on my 2000 looks original but i don't know it that is possible.
Old May 26, 2009 | 11:32 AM
SFeintuch's Avatar
SFeintuch
Dura Last 1000 CCA
Old May 26, 2009 | 03:46 PM
blowhole's Avatar
blowhole
Originally Posted by SFeintuch
Dura Last 1000 CCA
Where did you get that beast of a battery? And how much?
You are running the 6.0L, did you put two 1000cca batteries in your Ex? That thing must spin up like it is going to pop!!
Old May 26, 2009 | 03:54 PM
SFeintuch's Avatar
SFeintuch
I believe Auto zone sells them, I got two as a present so I'm not sure what they sell for. Check online.
Old May 26, 2009 | 06:10 PM
EXv10's Avatar
EXv10
A lot of people make 950-1000 amp batteries.
Old May 26, 2009 | 06:49 PM
VaSheriff's Avatar
VaSheriff
Dura Last 1000 CCA
I bought one last winter for my Excursion. It was $79.95.
Seems to have been worth every penny too. Plenty of cranking power.
Old May 26, 2009 | 08:27 PM
william_04_x's Avatar
william_04_x
I've read alot of good reviews on those DuraLast 1000CCA batteries...
For now I have Motorcraft 850's...They've held up well..
Old May 26, 2009 | 08:28 PM
Slamdunkpro
New battery - problem solved - thanks all
