Please help!! Changed out the HPOP
Old May 25, 2009 | 08:06 PM
thepwood's Avatar
thepwood
I had oil Pouring out from under the HPOP, so I changed it. Now it won't fire. A mechanic told me It was probly the Ipr. should there be oil on the IPR? Does anybody have any information on the Ipr? Is there a oring on the nut at the end of the IPR? The truck will fire on either (I removed the air heater) but won't fire on fuel Any Sugestions?
Old May 25, 2009 | 08:09 PM
BigJake34452's Avatar
BigJake34452
is the reservoir about an inch from the top?
Old May 25, 2009 | 08:11 PM
machmedic's Avatar
machmedic
Takes a lot of cranking to get the air out. DO NOT use either in these engines.
Old May 25, 2009 | 08:14 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Did you make sure the HPOP is full of oil? Take the plug off the top of the HPOP and make sure the oil level is no more the 3/4" from the top. Fill it with oil if it is not to level.
Old May 25, 2009 | 08:36 PM
megawatt00's Avatar
megawatt00
Ditto
Originally Posted by miller_feed
Welcome to FTE.
Double ditto. Also make sure that your batteries are up to par. All the excess cranking and you can drop them down quick. You need 10.5 volts for the IDM to fore the injectors.
Old May 25, 2009 | 09:20 PM
mudmaker's Avatar
mudmaker
Make sure the nut on the IPR is tight, be careful though as it is a weak nut. Was the IPR already on the new pump or did you swap it out from your old one? There is a write up somewhere on putting new o rings in the IPR, but I cant find it right now. If I find it I'll post it.
edit: found it http://cw-diesel.com/LuxSite/IPRInfo.htm
Old May 25, 2009 | 09:48 PM
thepwood's Avatar
thepwood
I filled the HPOP full of oil, and kept on adding till it was full. I cranked it for about 1/2 an hour 3 days in a row. Took about 6 years off my battery chargers life. Ha ha. When any one of the eight plugs off the head oil barly seeps out while turning over.
Old May 25, 2009 | 10:15 PM
thepwood's Avatar
thepwood
It was the old IPR that i put back in, I also rechecked the gear was installed right on the pump and torqued to speck
